Some EGR related questions
First off I took my truck to a friend of a friend who works for Navistar. He hooked my truck up and determined I had a faulty EGR valve. I am trying to decide if I need to replace the valve right away before I do a delete or if I can wait a couple of weeks. I saw that EGR valves are around 150 dollars, unless someone knows where to get them for a better price?
What are people paying for delete kits? The guy I had scan my truck has a new one that he got (somehow) and is offering it to me for 50 dollars. He says about 500 to install, so I'm not sure what a good price is. This is what he has http://i.imgur.com/ksCbB.jpg I was thinking about doing the delete that welds the end(s) of the factory cooler though.....I had read that it's a better option to maintain the strength of the up pipe to prevent cracking? |
OK how did he say it failed? was it stuck open? if so then clean it the most likely reason it is stuck open is because the egr cooler is starting to go bad. right when they start to go bad they make little carbon balls from the coolant starting to leak into the egr passage and if you break them open they are Grey inside. i would just clean the carbon of the valve then reinstall it. don't get any solvent in the vent hole under the valve or it will ruin it. put your egr delete on and cap the hole for the valve.if you looked at the voltage of the valve it should be around 0,84 to 0.89 volts when they stick open it will read around 0.93 to 1.12 volts
Sent from my Autoguide iPad app |
He tested it after I had already cleaned the valve the night before just for good measure.
The problem I've noticed is at idle, it will die off to about 500, then try to rev itself back up to about 1k rpm. It has only happened about 3-4 times, but that's 3-4 times in just under two weeks of ownership. Is 500 dollars to install the delete kit a pretty fair price? |
Don't buy a new egr valve if your putting a delete kit on the truck the delete kit has a block off plate that covers the hole on the intake manifold where the egr valve goes. 50 bucks for a NEW egr delete kit is a steal you should jump on it if its a complete kit that includes the block off plates and new up pipe as well. If not rivercitydiesel.com has the whole kit for $199. As for installing it if I were you I would be getting hands on here and pocketing the $500 and putting it towards something useful such as a monitoring system such as Dashboss or an edge insight cs/cts. Just my $0.02.
