Glow Shift vs. Autometer - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 54 Old 01-28-2013, 07:05 AM
Originally Posted by buck 01 View Post
How did yall mount the fuel pressure sending unit without it ribbon your radiator hose.
I used the adaptor from Strictly Diesel, it comes with a length of hose so you can place the sensor where there's room.
67rstbkt is offline
post #22 of 54 Old 01-28-2013, 08:02 AM
Glow shift sucks if you get one of the 7color ones the ending unit rubs your radiator hose I call and said I could put a hose on it but they don't sell one but if I would have bought the digital guage the sending unit is smaller. Said they never herd of my problem. Has any one had this problem. 79$ for guage had to by wire and stuff to hook it up 8$ adapter now 50$ for hose from strickly diesel. Dam sounds like bull **** why don't they tell you this **** could have bought the 3 pod for what its going to cost me for one. JUNK.
buck 01 is offline
post #23 of 54 Old 01-28-2013, 08:05 AM
I don't know what to tell you except it is what it is. The gauge is not custom made for a Ford 6.0, it's a universal setup used in lots of applications. Buy a different brand if you're not happy with it.
67rstbkt is offline
post #24 of 54 Old 01-28-2013, 09:04 AM
DoubleDpsd's Avatar
Re: Glow Shift vs. Autometer
Stomp your feet some more dude. Or help yourself and go to napa with the adapter and sender and get a 45° or 90° brass elbow. Good greif...some people.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #25 of 54 Old 01-28-2013, 09:39 AM
The point is I alread had everything apart now have to put together and drive 20 mile to town. I don'tneed a smart ***. Some people right.
buck 01 is offline
post #26 of 54 Old 01-28-2013, 09:47 AM
By the way just measured and sending unit to long will either hit fan or intake. Guess that won't work will have to get hose.
buck 01 is offline
post #27 of 54 Old 01-28-2013, 09:48 AM
If their universal why even ask year make and engine size. Junk.
buck 01 is offline
post #28 of 54 Old 01-28-2013, 09:53 AM
doubledrop's Avatar
In case u want a pillar pod? It's not for the gauge
Sent from AutoGuide.com App
__________________________________________________ ______________________________
doubledrop is offline
post #29 of 54 Old 01-28-2013, 10:02 AM
doubledrop's Avatar
Look I understand the frustration. Been there before with having things apart and needing something else. Strictly Diesel didnt make that line for 'just glow shift' it's for any sending unit that has same issue. Also to get it away from the heat and vibration it would get in that location. But cAlling a company 'junk' for that reason when sending units for much more expensive gauges can have the same problem is why people were gettin on u I assume
post #30 of 54 Old 01-28-2013, 10:15 AM
Well when I called the the said I couldn't use a hose longer than 12 inches and they where working on one why didn't they say I would have to get one some where else seems they know about the issue. Now the hose from strickly diesel is 36 inches and they said it want work. So I asked what do I do they said not sure. They said try a hose off a grease gun.
buck 01 is offline
