Towing with an sct programmer - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-28-2012, 06:47 PM Thread Starter
I have an 04 with an intake and 4" exhaust. I pull a 5th wheel camper that might weigh 8k lbs. I bought the sct programmer with the box tunes. My question is I have no egt gauge and was wondering if any of the towing tunes would be safe. Any info would help. Thanks
mrbucket1210 is offline
post #2 of 9 Old 07-28-2012, 06:56 PM
crashtest22's Avatar
Send a message via AIM to crashtest22
when in doubt.....dont......
thats what I have always gone by.
you could get a plug in monitor like the outlook from bullydog or edge CTS or something of the sort and install a pyro fairly easy and in about 1 hour
James (crash)
2005 PSD Crew white short
4 inches ish lift with big tires
4 inch turbo back with no kitty
ARP with OEM Gaskets X2
Airaid Intake
MTW Stage 3 Turbo
Spearco Turbonetics IC
Andy Warren Comp Trans
Warren 155/30
BP EGR Cooler
Sinister Coolant Filter
NUC Bypass Filter
SRL+,SPD, Warren Tow, Race depending on mood
PMF Traction Bars
crashtest22 is offline
post #3 of 9 Old 07-28-2012, 06:59 PM
I don't tow with tunes on myself but the questions you asked can go ethier way. The truck could have a good coolant and oil delta and face no problems. Or else you could blow a egr cooler and have hell to pay. If you got a couple hundred bucks laying around I suggest buying a edge for peace of mind and the knowledge of somthing failing before it does.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #4 of 9 Old 07-28-2012, 07:17 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
DONT TOW WITH THAT PROGRAMMER YOU WILL RIP IT IN HALF!!!
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 9 Old 07-29-2012, 04:49 PM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
You need to either return to stock when you tow, or get a monitor/gauges to cover what you need to be watching.
Way too many things can go wrong when towing with a any programmer, particularly when towing with generic files. My advice is to tow stock, until you can get the proper indicators, and custom files.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #6 of 9 Old 07-29-2012, 05:59 PM
Quoted: 2 Post(s)
I tow with a custom tune from Innovative Diesel. Not a lot of difference from stock. I would recommend custom tunes.
2016 F350 Platinum
ralderman is offline
post #7 of 9 Old 07-29-2012, 06:06 PM
jwsland's Avatar
I tow daily and use one of Vivian's tow tunes. Went for a year or so without gauges. I had them from my old psd just never put them in until recently. I just didn't beat on it when towing. My truck wasn't really setup like it is now and a couple hack mechanics worked on my rig which I think greatly contributed to the problems I've had.
Nobody is going to like this but here's the way I see it, if your towing (or racing for that matter) are you really gonna let off and pull over going up a huge hill for instance? Then what are you gonna do? Watch the gauge climb even higher getting up to speed? Try and take the time to get the truck dialed in correctly by taking a test drive and checking your gauges before experimenting on a trip.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #8 of 9 Old 07-29-2012, 06:18 PM
Maybe in that instance thats all you can really do is to continue till the top. Now if you were driving on flat ground and your FP for example dropped to 10psi you would stop.
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #9 of 9 Old 07-30-2012, 04:02 AM
first get a scangaugeII, to monitor the "vital temps", if all is good with the temps, then i would tow with the SCT tow tune, that should give you about 40Hp more than stock.
lubbock guy is offline
