::AIRDOG 2 USERS PLEASE CHIME IN::
Okay so with all the negative feedback on AD2s. I and Term3 thought it would be a good idea to start a thread and see who is running them. I want to know 1) Have you had any problems 2) How long have you been running it. 3) Are you using a sump. 4) Have you made your own wire harness, if so what size while and have you had any problems since. 5) How do you get the power i.e- batteries or alternator. 6) Did you use the fuse tap or tap into the factory harness? 7) where on the frame is the pump mounted. 8) What psi is your fuel pressure set at. 9) Anything extra like 'how many pumps you went though' etc...
Just wanted to make sure all portions where covered, if you think I missed something pm me and I'll add it. Thank you Last edited by Fox Hunt; 07-29-2012 at 01:15 PM. |
I have the Air dog 2 system, no sump, wiring harness from Air Dog and no problems. Still on the original pump I installed from Air Dog 2. I used a toggle switch from the battery to the pump. Has a 30amp relay inline and 20amp fuse at the battery. Plus a 20 amp fuse after the switch. I have my gauges wired into the same power supply so I remember to turn the switch off.
When I turn the key on I turn the pump on when the wts light goes off I start the truck up. Again I have had no problems with this set up and I am really pleased. |
Don't forget to say how long you guys have been running your AD2 and also if you've done any changes to the suction and discharge lines for the pump.
On my third DF-165 in 2 years. First replaced in 6 months for not maintaining fuel pressure. Last summer I started having pressure problems with 2nd pump. At that time I sumped the tank and replumbed the entire fuel system eliminating all of the stock fuel system components. Tues. 7/17/12 2nd pump died altogether stranding me in upstate NY. I purchased a replacement DF-165 and am about to build a new fuel system with the DF-165 feeding a Fuelab Prodigy 41402 HP pump. My DF-165 is wired with the AD harness tapped into the stock pump harness to activate. Both new fuel pumps will be rewired with 10 gauge power and 30 amp relays powered directly from the Alternator.
I've been running mine for about three months. It seems to be running fine. I have had to replace a motor within two weeks of installing it. But it's running good now. I have a spare motor just in case.
The system is flawed. I wouldn't buy it again. They might as well just bump the price up, include a high-amp alternator, fuel sump, bigger lines, external regulator, and upgraded wiring harness. Because the AirDog would benefit from all of these I listed. |
Had mine for about a year. Had to replace the pump 2 days after install due to it pumping fuel through the wire harness. Followed the instructions and ran the power feed from the battery. Havent had a problem with the second one and overall love the system.
Mine was hooked up per the directions. I'm not running a sump, Its wired to come on when I turn on the ignition. used thier wiring harness. I carry a spare pump just in case because I drive so much for work. I am on my 2nd pump. I got over 100k on the first pump in about 18 months. I haven't had time to research why the pump stopped.
EDIT: pump is mounted on the inside of the frame rail rear rear door. and the pump is set to 55psi Last edited by mudrunninpig; 07-29-2012 at 04:54 PM. |
have gone through 3 pumps, wired to the battery with the airdog harness, had it for 2 years now. have a sump on it and its running at about 67psi and then i have the rr on the motor as the main regulator. overall i wont buy one of these again. about to be on my next pump here in a few days as the second one wont hold pressure again!
Added two more questions to the original post. Keep them coming guys I know there are more than that using them.
