4" exhaust - EGT gauge
Does anyone know of a 4" turbo-back exhaust system I can buy that has a pre-drilled hole for the EGT probe? Or does that install pre-turbo?
TIA |
you want to install your EGT probe on your manifold not the exhaust.....
yea you wanna install the probe preturbo. Of you had a post turbo than your turbo will be getting hotter than the reading you get on your guage
Damn. I was hoping for an easier way.
Thanks :-) |
It's really not that difficult. People make it out to be more than it is. Just drill the right size hole (21/64) for the tap (1/8" NPT) and get the tap started straight. It's even easy to get to.
If you wanted to tap your downpipe, you really need to weld a bung on the pipe because it's not thick enough to tap. Also your temp readings would be about 200 degrees lower post turbo vs pre turbo (manifold). |
Tapping the manifold is really easy. You dont even need to unbolt anything, just crawl under the drivers side look straight up and there is the exhaust manifold.
