OK guys so I decided I am gonna go ahead and start taking the truck apart and do the head gasket work myself instead of paying a shop... so I am starting a build thread. Please check my parts list below and tell me if I am missing anything as this is my first build on a 6.0. I already have Edge CTS, AFE intake, and MBRP 4 inch turbo back exhaust. I decided that I might as well do everything on the how to make a 6.0 bulletproof sticky while it was all apart. The only things off that list I didn't decide to do was the remote oil cooler kit and the oil bypass filter setup.
I have 36 gallons of distilled water, a gallon of restore, a gallon of restore plus, and 4 gallons of CAT ELC for the coolant flush process. injector o rings - 3c3z-9229-AA oil cooler - 3C3Z6A642CA 6 new copper crush washer for fuel lines - 3c3z-9A375-AA 2 orings for oil tube - W300012 2 orings for oil tube - W302209 2 orings for oil tube - w301390 2 orings for oil tube - w301386 Ford intake manifold gasket set - 3C3Z-9439-AA Ford head gasket kit - 4C3Z-6051-EB Ford exhaust gasket set - 6C3Z-9448-A Ford valve cover gaskets Ford Turbo Bolt/O-ring and gasket Kit Ford Blue Spring fuel pressure regulator kit 6.4 Banjo Bolts Updated Dummy Plugs - W302908 Updated Stand Pipes - 6E7Z9A332A STC HPOP fitting update kit - 4C3Z9B246F Updated oil drain tube - 6C3Z9T515A Updated oil feed line - 3C3Z9T516A XDP 6.0L Coolant Filtration System ARP Studs - 250-4202 EGR Complete Delete Kit EGT, FP, and Volt gauges in triple pillar pod 6.0 Fuel Pressure Adapter from strictly SCT X3 with tunes from Vivian Heads cleaned, pressure checked, and resurfaced AC system Drained before tear down The total for all the parts including shipping is $2686.30 not including the coolant flush supplies I already had. |
Subscribed. Take lots of pictures and good luck.
I will for sure. My Ford workshop manual should be here tommorow. I am going to do it without pulling the cab or motor. I just gotta get my truck in the shop to get the ac system drained so I can do the coolant flush and start pulling it all apart. I am hoping it will be damn near bulletproof when I am done with it. the i can start on the fuel system mods.
If I'm thinking right, the o rings you are referring to for the oil tubes are for the standpipes and dumby plugs, the new ones come with the o rings already. Also the head gaskets include new stand pipes.
see thats why i post on here cuz u just saved me 25 dollars in o rings... every penny counts lol
Spend some of that savings on an extra tune of ultra lube for the studs. The little packet they give you is not quite enough.
Ok thanks I will do that... keep the little tips and tricks coming guys... I can never have enough knowledge
I'm just finishing up this same project this week. PM me if you have any questions.
oh ok thats aweseome... did i forget anything on my list?
Did u do it with the motor in and cab on like I am going to? About how long did it take? |
You'll need a set of rocker box gaskets too, 3c3z 6584 AA |
