top 5 performace mods you would do..... - Ford Powerstroke Diesel Forum
Old 07-24-2012, 05:18 PM
Lets hear some opinions. I just bought my first diesel. Its under warranty and is not studded. I would like to get some info from everyone. I want to keep the truck at its peak without blowing the gaskets. If there are things to make it run cooler, last longer and get better fuel milage I am going to try it. I am easy on the throttle for the most part, I am not going to be making payments on a truck that is blown up. I currnently have a SCT (erics extreme street) and will be ordering exhaust next month...other thank those, I am in the dark. Thanks.
Old 07-24-2012, 05:30 PM
#1 Sinister Diesel Coolant Filter
#2 CCV Mod to keep oil out of the CAC Boots
#3 EGR Delete -Bulletproof (Most Dealers will do this for you and shouldn't void your warranty)
#4 ScanGauge II
#5 Fumoto Valve on Oil Pan
There's an entire other list once it's out of warranty....
D
Old 07-24-2012, 05:42 PM
#4 ScanGauge II
D
Thanks, #2, and #5 I have not heard of. I will look into those. Thanks again
Old 07-24-2012, 05:44 PM
I Love Workin On Hotrods
#1 IPR coolant filter
#2 Edge CTS/CS with EGT probe
#3 IPR EGR delete
#4 New OEM Oil Cooler
#5 Head Studs (one for one swap as long as you know your head gaskets are still holding)
#6 MTW Stage 1 Turbo
I know you said 5 but this is what I recommend for your build. This will make your truck into a solid and dependable daily driver that is fun to drive and gets good mileage. I also recommend you give Vivian's Looney Wild tune a try.
Old 07-24-2012, 05:45 PM
Real Men Love Jesus! <><
Head studs, monitor or guages of some sort to watch EOT/ECT, egr delete, oil cooler( both from bulletproof), exhaust
Old 07-24-2012, 06:01 PM
#3 IPR EGR delete
Thanks. Sounds good. 5, 6 or 7 aww whos counting. I can understand that its hard to get what I am looking for with 5 options, just that I am going to try to keep it resonable, as I complete two or three of the mods I will ask for some another 5..lol
Old 07-24-2012, 07:33 PM
Powerstroke Techie
Feedback Score: 8 reviews
well if you haven't already start with t fitting stand pipes and dummy plugs to make it dependable the go hog wild on rest!!! just a thought!!!
Old 07-25-2012, 06:55 AM
Can you explain, for I am not familiar with the diesel engine. I would just like to know whats the purpose for them and why you change it..I know it might be a stupid question, but I dont want to be stupid forever..lol Thanks.
Old 07-25-2012, 07:02 AM
Powerstroke Techie
No question is ever stupid and the reason why you change them!!! It will leave you setting someplace you don't want to be. They are the weak link!!!!
Old 07-25-2012, 07:29 AM
What he is referring to is the High Pressure Oil (or Injection Control Pressure) Stand pipes and Dummy plugs. Our engines' injectors use the oil in the motor as hydraulic fluid that is pumped to around 4000psi via a High Pressure Oil Pump (HPOP). He is stating that if you tear into the motor and pull the heads for stud installation, you should also replace the Stand Pipes and Dummy Plugs with updated ones that have urethane washers to help hold the orings in place better and be less prone to being cut and start leaking. A general flow path is that the Low Pressure Oil Pump (LPOP - pump that supplies oil to the bearings and turbo and stuff) feeds oil to the HPOP which then sends the oil to a rail that has two pipes that plug into it that the oil goes through to get to a rail on the heads to send the oil to the injectors. Hope this helps a little bit better.
