truck started acting up...TPS sensor maybe? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-23-2012, 11:03 AM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
Damn, truck started acting up alot today. Put it in drive and start to accelerate...then all of a sudden it'd go flat on it's face. When it does the glow plug light would flicker like once or twice then go out every time this happened. I also noticed that on my edge insight the throttle postition setting would stay on the certain % when this would happen. It just so happened that the last time it did this the pedal postition was at 25% and stayed there even in park idling. Makes me think the TPS sensor is taking a dump. Anyone got any thoughts
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 2 Old 07-23-2012, 05:25 PM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
Well it's not the APP(accelerator pedal position) sensor. Swapped the one out of my cousins truck and it didn't change anything. However my truck started stalling now also. But i found out that once it got up to temp it stopped doing it...so i'm at a loss right now. i'm not sure i actually feel safe driving it because it actually stalled on me while driving. It did throw a code...P2614 camshaft position signal output circuit low. But the truck will automaticlly throw that code when it stalls so i'm not 100% sure that it can be the camshaft sensor
