question about blue spring upgrade... - Ford Powerstroke Diesel Forum
Old 07-22-2012, 05:25 AM
Good morning, Im getting the courage up to tackle the blue spring upgrade. What I have found is you can buy the "kit" with or with out a new cover/housing that just bolts up on the side.
So question is,is the extra cost of the new housing justified? Thanks
Sorry if this has been covered a hundred times....but I just need to know once!
Old 07-22-2012, 06:26 AM
i just ordered the part from international comes with o rings spring all you need it was like 30 some dollars hope this helps
Old 07-22-2012, 08:29 AM
Thats what I have found. You can order the one that you did for around $30. Or you can order the one's with the cover for around $60. Just trying to figure out,1) is it something that warps or breaks easly? 2) is the 30 extra reeley worth it....
Old 07-23-2012, 02:54 AM
Cover is not necessary, spend your $30 else ware
Old 07-23-2012, 06:04 AM
X2 for no need for buying the cover. Just undo the intercooler pipe from the intake elbow and rotate it out of the way then use a rope to pull the rad hose a little out of the way, then undo the #27 Torx screws and pull back the cover enough to pull out the spring. I've seen a number of guys kink their fuel lines trying to take them off which is unnecessary.
Old 07-23-2012, 07:38 AM
Tousley ford google it
Old 07-23-2012, 07:51 AM
Send a message via Skype™ to bwmtnbiker
I bought the cover for mine only because mine had 305,000 miles on it when I replaced it... I got the cover just cause it seemed like a good thing to do.
Old 07-23-2012, 09:06 AM
^ how's your tune by Vivian? You running the looney? I have exact truck just less
Miles
Old 07-23-2012, 12:27 PM
Miles
It is freakin sick, my truck loves her tune. A guys truck who I met this weekend said his truck ran like crap on her tunes. Mine will squall my 37's...
What brand and wattage are your HIDs?
