Need to know if stock injectors with a bigger nozzle will work or be any good!! - Ford Powerstroke Diesel Forum
Old 07-21-2012, 09:15 PM
Will putting say 50% nozzles on stock injectors mess them up or do I need to get a bigger cc injector!!
Old 07-22-2012, 03:47 AM
What are the goals for your truck and what is done to it? That would make it easier to answer your question.
Old 07-22-2012, 07:39 AM
So far intake,4in straight pipe,egr delete. And getting the blue spring upgrade soon and an sct I just want to know if bigger nozzles will work with stock injectors
Old 07-22-2012, 12:24 PM
The answer is yes you can put bigger nozzles on stock injectors. Depends on your definition of "will it work" whether the outcome will achieve what you want. It will add power up top and smoke more down low adding to EGT's.
Old 07-22-2012, 01:15 PM
If I did the nozzles befor the sct will that harm anything!!! Probably just be laggy I'm guessing!!
Old 07-22-2012, 02:11 PM
Yes, the pulse width on the injectors will need to be adjusted or it is going to smoke and get hot down low. I would suggest you get the SCT and a tune before worrying about injectors. Just the tune will put you in the 380-400 rwhp zone.
Old 07-22-2012, 03:45 PM
What are the best tunes out right now
Old 07-22-2012, 04:11 PM
Maybe you should start a thread with Hi my name is _____ I have a _____ I use it to ______ and i'd like it to ____________
What would be the best and least expensive or in some cases most expensive way to accomplish the above goals..
Just a suggestion.
Denny
Old 07-22-2012, 08:12 PM
Thanks I will do that
