Mbrp downpipe
I just got a mbrp 5" turbo back exhaust. And I was just wonderin if there was a reason why they only make 3.5" down pipes instead of a 4"
Because you have to beat your firewall in to get the 4" dp to fit. Also the 4" is overkill unless you have supporting mods necessary for a bigger dp. Eg; injectors, turbo, exhaust headers etc.
That would make sense. Thanks for the reply.
Lol no problem.
I just wanted to add that I have a 4" DP on my Magnaflow exhaust and I didn't have to beat or modify anything to get it to fit...
I have a 4" on mine and I didn't either but some people I know personally had to beat theirs in to get it to fit but they also had 2003's and 2004's so maybe it was different then.
4" DP on my 04 Excursion with literally no issues at install.
My '04 has a ZF6 and the 3.5" MBRP pipe is VERY tight between the back of the starter boss on the bellhousing, frame, and firewall seam. I think that if a manufacturer could be bothered to make a special downpipe for the manual transmission trucks, a 4" might be OK. Problem is that it's a small market segment, so volume would probably be too small to make it worthwhile. It's so much easier to market a 3.5" downpipe that fits everything poorly, and a 4" labeled "automatic transmissions only." At only a little over $200 for the whole system I can't complain too loudly, but will probably try to do something different if/when it needs to be replaced.
My 4" diamond eye went in without any problems and so did the rest of my 5" exhaust.
Motor placement, cab placement from the factory will make a difference. MBRP could have the bend off the turbo just a tad less then other exhausts. FWIW I doubt anyone has a setup that will not flow properly with a 3.5" exhaust.
