Edge Egt Sensor Install Question - Ford Powerstroke Diesel Forum
Old 07-18-2012, 10:16 AM
So I currently have the sct 9600 installed & the egt sensor installed. Well today I ordered a new edge insight cts and egt sensor my question is will it hurt anything to just unscrew the old egt sensor from the manifold and screw in the new one. Or will I need to take some extra steps to do it all correctly?
Old 07-18-2012, 10:20 AM
The Silent Service
As long as the two probes use the same fittings, you shouldn't have any issue. Unless the probes are differnent diameters, in which case you may need to thread the new fitting in the manifold.
Old 07-18-2012, 10:24 AM
Ya I looked into that says they both are 1/8 inch fitting so should be good on that part I hope.
Old 07-18-2012, 10:25 AM
The Silent Service
You'll know for sure when you look at them, but I'm not expecting any difficulty.
Old 07-18-2012, 10:57 AM
I'm also thinking about selling the entire sct package and just going with the SCT SF3, how hard would it be to transfer all my tunes over to that?
Old 07-18-2012, 01:02 PM
I'm pretty sure the tunes are written so they only work with your programer, you will have to get with whoever wrote your tunes to get them changed to work on a new tuner. I'm sure someone will chime in that knows for sure.
Old 07-18-2012, 02:05 PM
Feedback Score: 3 reviews
You are correct. The tune writers lock the tune to the serial number on the SCT device. They will only work on that device.
Old 07-18-2012, 02:17 PM
I wonder what they will charge to convert the tunes over to the new programmer?
