IDLE RPM - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-10-2007, 03:39 PM Thread Starter
IDLE RPM
What is your idle rpm? Have any of you changed it with your sct or other programmer? If so why and what are the reasons? Thanks
Sold it for the Vette Now Want Another!
06F-250-6.0 CC SB 4"TB Silverline No Cat SCT XCal2 DJ'S Econ, Street Smoke, Looney! Innovatives Xtreme Race
, Xtreme Street
Quadzilla Commander A-Pillar Mount 2 12" Solobaric L7'S & Kicker 1000 watt amp. High Idle Mod, CFM+Intake Elbow...............Coming Soon! Injectors, Turbo, ARP Head Studs
06F-250-6.0 is offline
post #2 of 5 Old 10-10-2007, 03:40 PM Thread Starter
mine is around 650-700
, Xtreme Street
post #3 of 5 Old 10-10-2007, 04:00 PM
back in the saddle
shu873's Avatar
Mine idles a 600rpm, in cold weather it will idle up to 950 sometimes. I installed a high idle switch which when the E-brake is set in park it will idle up to 1200 when I flip the switch. The reason for doing this is to prevent wet stacking (carbon build up). IMO anytime you're going to idle your truck for 10 minutes or more its a good idea to have a high idle.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #4 of 5 Old 10-10-2007, 04:03 PM Thread Starter
i did the high idle mod also....
, Xtreme Street
post #5 of 5 Old 10-10-2007, 06:21 PM
i havent done the hi idle mod yet, but i need to because i idle my truck A LOT
LvTitan is offline
