ADII DF-165 took a dump on me - Ford Powerstroke Diesel Forum
post #1 of 33 Old 07-17-2012, 06:17 PM Thread Starter
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
And left me stranded in upstate NY today. Got the truck all loaded up tp go home to Md. and when I went to syart the truck had NO fuel pressure. Called Pureflow at like 1:30pm and was told they couldn't shop a replacement until tomorrow so I'm down till sometime Thurs. I took the pump apart and everything looks like new. Changed the filters just to rule them out but no change. Oh well, more down time.
Sent from my Droid using AutoGuide.com App
RIP Mitch
the Org crew
PGreenSVT is offline
post #2 of 33 Old 07-17-2012, 06:30 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Man that sucks Mitch. I am really sorry to hear that. I hope Pureflow gets a replacement to you quick.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 33 Old 07-17-2012, 06:48 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Man, that sucks! You would think that there was something they could do to keep you running. Not only are you on a trip away from home, but you are also a staff member for the largest Powerstroke forum in the world!
Sent from my iPad using AG Free
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 33 Old 07-17-2012, 07:16 PM
BACKYARDIGAN
Quoted: 4 Post(s)
No kidding Shawn.
Nate
post #5 of 33 Old 07-17-2012, 07:21 PM
Quoted: 5 Post(s)
Mitch,
As I told you when we spoke on the phone - if you need me to call my buddy and ask him if he still has his AD system I can overnight you the pump, not sure if he still has it just got rid of his diesel for ecoboost but I think he still has everything.
Just let me know - it sounds like you have it under control as always though
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #6 of 33 Old 07-17-2012, 07:28 PM
Mitch are you still using the airdog harness that came with the pump?
mikeproc is offline
post #7 of 33 Old 07-17-2012, 08:16 PM Thread Starter
PGreenSVT's Avatar
Yes I am. I have it spliced in to the factory pump's power line instead of going to the fuse block with their fused trigger.
RIP Mitch
the Org crew
post #8 of 33 Old 07-17-2012, 08:59 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Did the motor die? Try ohming it out? I got the 150 just because of that incase the 2 would die and leave me stranded. Good luck with it Mitch
I wonder if
That had something to do with your dyno runs at php
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #9 of 33 Old 07-18-2012, 03:41 AM
I had the motor fail on my pump and when it did it melted some of my airdog harness. The airdog harness is has too much voltage drop to run 16 or 17 amps constantly. They use 14awg from the batt to the relay to the motor. Do some research for a 20amp draw and a total wire length of roughly 20ft you need a minimum of 10 awg. I made up a new harness when I got my new pump from them and now my pump is incredibly quiet and I haven't had a problem since. I will get a short video of it running, the oem vacuum pump is louder then my airdog. I run a constant 65 psi drop about 2psi wot. I would bet airdog uses the same wiring harness for every pump. You wont run into problems with a lower amp draw using an airdog1. Just my thoughts. I find it very hard to believe your problem would be anything other then the motor.
mikeproc is offline
post #10 of 33 Old 07-18-2012, 03:55 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Check if its getting power if you can Mitch
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
