Turbo impeller/turbine torque specs
Ok, so I am rebuilding my turbo, and the one thing I forgot to make a reference mark was on the intake turbine/impeller to the shaft. Does anyone have any ideas about how tight to make it, or do you have the torque specs?
Thanks Last edited by jrv8984; 07-14-2012 at 03:21 PM. |
10 inch lbs IIRC
Sent from my Droid using AutoGuide.com App |
wow 10 inch pounds, that doesn't seem tight at all. I guess loctite will keep it together though
Remember it is reverse threaded so when spinnng it is tryong to tighten mot loosen.
