Banks ic and piping - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2012, 06:06 PM Thread Starter
kdogg85's Avatar
Banks ic and piping
I had one and it worked good, not worth the money but improved all the affected numbers in a good way.
My buddy who I helped finish a stick and pmax install this afternoon asked about the intercooler. I told him for what you have, it's a waste. An intake manifold would be better money spent, but even that shouldn't really be a need.
Now my question, there was a thread about the boost tubes being too big and causing lag and so on. Are there any opinions at what point the ic and larger tubing would come into play? I don't want a horsepower number, I want a general area of turbo and injector combos that the ic becomes a restriction.
We all know the intake manifold and heads are the buttplugs on the motor already so that base is covered and we can skip that.
I put mine on after my pmax went in, all i noticed was an egt drop at wot and a loss of 2psi of boost. I have no before and after to compare after that so i couldn't give an opinion.
Thanks in advance folks.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #2 of 7 Old 07-11-2012, 06:19 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I dont think people really replace the stock intercooler because it is a "restriction" per say but rather that it has small end caps (so most of the air flow is forced through about 50-60% of the cooler) and is not as thick as say a banks or spearco intercooler and is used for additional cooling of the charge air. At least that is why I did my intercooler swap.
Either way, I agree that a ported intake manifold would be a better option first.
I think when guys put larger injectors like 175s + are used and a turbo that is larger than a Pmax is put on, the air flow is going to be higher and therefore the cooling capacity needs to be more so it can help keep IATs down and thus EGTs down as well.
JMO take it FWIW.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 7 Old 07-11-2012, 06:26 PM
for me I installed the Pmax first and then the BANKS IC and piping. I have alot better throttle response with the banks kit over the stock stuff and even smoked less. Also egts over all where lower and cleaned up quicker. As for the boost I would be more worried about increased boost over a loss. when you build more power with increased engine efficancy with out increasing programing for more boost or fuel, boost will drop. Also as air density (cold air) increases boost will drop due to the air taking up less space for the same amount of air moved. the only way to show weather the tubes are good or bad would be to test on a dyno back to back. for me it's a double thumbs up for the whole setup.... my 2 cents anyway.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #4 of 7 Old 07-11-2012, 07:52 PM Thread Starter
kdogg85's Avatar
Both points taken, an intercooler is just an air/air radiator. the banks/afe/spearco seem like the aluminum 4 cores and the stockers seem like the 2 core copper rads.
I would venture that a monster setup(some compound configuration) would be the no brainer candidate. Just curious about the grey area before
David
kdogg85 is offline
post #5 of 7 Old 07-11-2012, 08:29 PM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
I see the intake manifold as the hold up in close-to-stock builds.
So the plan now is to get my manifold ported out, the next time I rebuild the oil cooler (next spring).
This fall will be the addition of a new turbo. So I should be able to give solid numbers back on what I see with the turbo, intake manifold, and then the intercooler.
I think the 6.0L intercooler works when matched with the stock intake manifold, but if you open the air down stream, you should really see gains when the IC goes in.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #6 of 7 Old 07-12-2012, 03:01 PM Thread Starter
kdogg85's Avatar
I had mine about as open as it got. the pmax seemed to run around 650-750 no matter what airflow improvements I made(manifold, headers, ported heads, intercooler.) The compond setup ran about the same area. One scenario that was different was climbing a small hill, giving the engine just enough throttle to maintain speed. The pmax would climb to about 900(stock and 175 injectors) while the compounds would only go to about 800. that told me the s364 was flowing a tad more at the same rpms vs the pmax(1800rpms for example.)
Towing, either outfit was setup to stay below 1100* egt WOT.
3/4-WOT was where the hard parts really shined and let the engine give its all.
David
kdogg85 is offline
post #7 of 7 Old 07-12-2012, 04:55 PM
just back from a beach trip and my egts on the way back with ambiant temps around 88 where 600-650 doing 70-75.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
