Too much fuel pressure? - Ford Powerstroke Diesel Forum
Old 07-10-2012, 09:18 PM
Can you run too much fuel pressure? The reason i ask this is because I was told to run 65PSI with my injectors (175/75) and being that i set my airdog at about 63 and jammed the nut back. Well i have drove it for a little bit now and it seems that my pressure has creeped up to about 75PSI! Is this bad or should i just leave it?
Old 07-10-2012, 09:21 PM
u can run too much and the orings won't appreciate it but 75 is about the upper limit and I would say your ok there
Old 07-10-2012, 09:34 PM
Ok thanks for the quick response! Not that i dont trust ZMANN but keep the answers coming i always like having more than one!
Old 07-10-2012, 09:37 PM
Ohh no offense
I just reiterate what I read ,, the more input the better !!
Old 07-10-2012, 10:11 PM
80psi is the generally accepted upper limit as I recall so you are ok there. That's where mine is at the moment too.
Old 08-07-2012, 07:40 PM
Glad to see the answer from PGreenSVT. I thought 75 was the limit and I just noticed 80 on my way into work tonight. So now I'm on here looking for what to do when or if it gets over that.
Old 08-08-2012, 06:01 AM
International Specs are 70PSI max.
Old 08-08-2012, 06:23 AM
Yeah well my fuel pump also quit on me leaving me stranded 7 hours from home since this post. This is my 3rd pump in two years and I am now of the opinion that the DF-165 is just not capable of sustaining that high pressure over time.
I had to buy a new pump to get home and have since ordered a Fuelab 41402 High Pressure Pump and 51501 FPR that I will be plumbing into my system as soon as they arrive to handle the High Pressure duties. The DF-165 will be dropped to 15-20 psi and relegated to feeding the 41402.
Some vendors have stopped selling the DF-165 as a HP pump due to the failure rate. At this point I can't really recommend them anymore either. The AD-100 and AD-150 are fine to use as feeder pumps and have been reliable in that role. For HP pumps I suggest the Fuelab or Aeromotive pumps at this time.
