MTW Stage 1 vs. Stage 2 vs. Stock all on my truck. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-01-2012, 06:44 PM Thread Starter
MWilbur516's Avatar
Well, I've gone from a stock turbo to a Stage 2, back to stock (after Bill at PHP stole my Stage 2) and I'm now running a Stage 1. All my testing has been done on a 2006 F250 ECLB 4x4 w/5R110 on 35's. My mods are as follows. S&B CAI, 58v QuickTricks FICM with PHP tuning, MBRP 4" straight pipe, 6.4L banjo's and custom tunes from Quick Tricks, TSD and IDP, stock injectors and fuel delivery. There are sh*tloads of other mods on the truck, but I feel that these are the important ones pertaining to the turbo performance.
I'll begin by saying that the Stage 1 & 2 are miles above the stocker. My truck loves the extra air and runs smoother, faster and gets better fuel economy on both turbo's. Both of these turbo's used the 13 blade turbine wheel so the exhaust note changed very little. The intake however does have a more pronounced whistle, but not enough to annoy my pregnant wife, so I'm gonna say it's very tolerable.
OK the Stage 1. This IMHO is a very nice turbo for someone who wants more power, but will never go beyond stock or 155/stock-30over injectors. The reason I say stock -155's is that this turbo will completely clean up the smoke from these injectors and keep the EGT's well within acceptable limits. This turbo will provide quicker boost with no dead spots and lower EGT's. Over the stock turbo I've noticed a 100+ degree drop in EGT's, BUT REMEMBER, I am running the Hercules 100 FICM tune. This tune removes all fueling restrictions on the low end so it is a HOT FICM tune. Any other FICM tune would see noticeably lower EGT's, closer to 200*+ (from what others have consistently reported). The back pressure has been between 1.27:1 and 1.41:1. This turbo has netted a 2mpg gain over the stocker that just came off. The power is good and the truck is noticeably faster, especially on the bottom end. Getting out in traffic is not a problem. This turbo made 473RWHP on the PHP dyno in 80*+ heat and high humidity on a Gearhead tune designed for the stock turbo. The Stage 1 will run on whatever tunes you already have (including stock) without any issues and noticeably more power, but some tweaking of the tune will further benefit performance. The tuning is still being worked out and we'll have more on that soon. As soon as I get a tune for these turbo's that I'm happy with, I'll let anyone interested know who to call and what to ask for. As for towing with the Stage 1, I havn't done any yet but will this week, however it won't be horribly heavy until I change this FICM tune.
The Stage 2. The thing is beautiful. I was extremely impressed with this turbo. The power was noticeably higher than the Stage 1. This turbo cleaned up whatever tunes I threw at it. The EGT's were 200*+ cooler than stock on all my tunes. It doesn't spool as fast as the Stage 1, but is still as quick to light as stock if not a shade quicker. Back pressure was between 1.16:1 and 1.35:1 depnding on the tune I was running. My truck produced 485RWHP with this turbo on PHP's dyno. The ambient air temp was 80+ and very high humidity. This turbo has produced 560RWHP on a truck with 190/75's in 90*+ heat on PHP's dyno. I believe this turbo could be used on naything from stock to 190/50's (some smoke at WOT) with great success. This thing is moving the air boys and girls. I was also able to net 23.5+MPG (highway driving 60-65mph with a little stop and go through a couple small towns) before I took it off the truck on a QT Looney Wild track file. The power was unbelievable. I could destroy the rear tires with no effort, but the truck remained as streetable as the day it rolled off the line until you squashed the skinny pedal. Again, this turbo will run on whatever tunes you already have (including stock), and run well, but will benefit from some tweaking in the tuning. The turbo exhibited very little lag, no surging and smooth consistent power throughout the RPM range. The truck cruised faster with less effort and was overall much happier with the Stage 2 over stock. I did tow with this turbo as well. 14K behind the truck and the turbo performed flawlessly. The load moved quicker and was held at speed easier with far less down shifting. I was running a IDP Agressive tow file with turbo brake for this test. My EGT's stayed below 1150* (ATLAS 80 FICM tune) the entire run. Ambient air temps were in the mid to upper 80's with normal GA humidity. The Stage 2 is a 64.7x88mm compressor wheel in a .72AR housing with a .90AR turbine housing. The new Hybrid turbo that will be debuting within the next week or two will be a 64.7x88mm compressor wheel in a .58AR housing with a .90ARturbine housing. The expected HP difference is 5-8 in favor of the Stage 2, but the price difference is looking to be fairly large. For these reasons the Stage 2 may soon be replaced by the Hybrid if the testing goes well and it performs as expected. As soon as I get the Hybrid you guys will get a review of it as well.
I've tried to give you the best reviews as possible with all the info I have, but please feel free to ask any questions you want.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #2 of 11 Old 07-01-2012, 09:14 PM
Country Mav's Avatar
Quoted: 2 Post(s)
So the Stage 2 is better all around for a stock injector truck? I don't think I'll ever upgrade my injectors but I'd love more fuel economy and lower EGTs...
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #3 of 11 Old 07-01-2012, 09:50 PM
nice its looking like i should just hold on to my 6.0 instead of goin 6.4. doesnt seem like to much work to get them as fast as the 6.4 with these new turbos out, but i do like there interiors
villain is offline
post #4 of 11 Old 07-02-2012, 08:33 AM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
The Stage 2. The thing is beautiful. I was extremely impressed with this turbo. The power was noticeably higher than the Stage 1. This turbo cleaned up whatever tunes I threw at it. The EGT's were 200*+ cooler than stock on all my tunes. It doesn't spool as fast as the Stage 1, but is still as quick to light as stock if not a shade quicker. . . This thing is moving the air boys and girls. I was also able to net 23.5+MPG (highway driving 60-65mph with a little stop and go through a couple small towns) before I took it off the truck on a QT Looney Wild track file. . .Again, this turbo will run on whatever tunes you already have (including stock), and run well, but will benefit from some tweaking in the tuning. . . I did tow with this turbo as well. 14K behind the truck and the turbo performed flawlessly. The load moved quicker and was held at speed easier with far less down shifting. I was running a IDP Agressive tow file with turbo brake for this test. My EGT's stayed below 1150* (ATLAS 80 FICM tune) the entire run. Ambient air temps were in the mid to upper 80's with normal GA humidity.. . .
Thanks for these numbers, particularly with the Towing figures. That's a good sized load for the tuning you had loaded, and I'm glad the Stage 2 works for you.
Sounds like the Stage 2 is a great stock-injector option. Just weigh the cost benefit of the Stage 2 vs the new Hybrid that's under development. The only real difference will be the housing it sounds like (.58 A/R vs the .74 A/R of the Stage 2). It should be moving similar amounts of air to the Stage 2 and cost a few hundred less. I'm waiting for the testing results on the Hybrid myself, though I'm leaning toward the Stage 2 in my tow build.
These new turbos are breathing a new life into the 6.0L. Its had great injector options, but these are the first turbos to really be able to take advantage of them.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 11 Old 07-02-2012, 09:02 AM
bwillis2003's Avatar
Will be waiting for the Hybrid vs. Stage 2
Brandon
2007 F-250 6 point oh
146,000 miles
2.5 inch BDS leveling kit
35" Toyo Open Country A/T
OEM rotors w/ Hawk LTS pads
5 inch custom sidepipe
Edge Insight CTS
SCT X3 w/ Innovative Tunes
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
FICM fixed by Ed/tuned by PHP
S&B Intake
Dfuser Coolant Filter Kit
2003 F-250 7.3
84,000 miles
SOLD
bwillis2003 is offline
post #6 of 11 Old 07-02-2012, 09:15 AM
new2deisel's Avatar
I am really interested in the Stage2 but this hybrid has caught my eye now. I have read pretty much every thread that has to do with these turbos, but there is so many that I get lost and confused. So all of these turbos need my stock turbo to be modified? What is used off my turbo? Can a Pmax be modified into a Stage2? When it is said that there is a 200* drop in egts, is that throughout the entire power band? Do the egts dropped that much on WOT too?
new2deisel is offline
post #7 of 11 Old 07-02-2012, 09:39 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Great review Matt I can't wait to hear how the "Hybrid" works out for ya.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 11 Old 07-02-2012, 10:43 AM
Hillz's Avatar
Quoted: 2 Post(s)
Outstanding review!! Great information! I am one of those who are between the 1 and 2. I will be looking forward to the hybrid review! I assume you are running stock injectors? Not to get off topic, but are you able to to run the 100 Hercules with Gearhead tunes and stock injectors?
2005 F250 4x4 ECSB.
Stage 2, SCT X3, ARP , 4" turbo back Magnaflow duals, No limit CAC, S&B CAI, EGR delete, Dieselsite coolant filter, Nuc engine oil bypass filter, Dfuser fuel cross over, GoGo direct solenoid, Autometer gauges, 2.5" leveling, 35`s, Bilstein 5100, Rear air bag, 7.5` Arctic poly plow
Hillz is offline
post #9 of 11 Old 07-02-2012, 04:15 PM
madpowerstroke's Avatar
The drop of egt is through out the whole rpm band, the turbo pushes that much more air. Great write up, and I know that there are alot of threads and hard to keep track of them, sorry about that.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #10 of 11 Old 07-02-2012, 05:34 PM
xu67585's Avatar
Quoted: 5 Post(s)
Garage
Thanx for the great review! I'm trying to soak this up as fast a you guys put it out! I'm also interested in the hybrid cause as of right now I'm thinking stage 2 with 175's but it's going to be a few months before I pull the trigger. I look forward to hearing more.
Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App
2005 F250 SC SB
ARP Studs, RCD Egr Delete, Homemade Coolant Filter, Stand Pipes And Plugs, Banjo Fittings, Blue Spring,
STC Upgrade, FleetGuard ELC, Cat Delete, Zoodad Mod, CCV
xu67585 is offline
