53 or 58volts? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-28-2012, 02:08 PM Thread Starter
xjeeper's Avatar
53 or 58volts?
My BPD FICM gets here friday what voltage should I set it on? Right now I have the old PHP FICM rollback, but I will be adding an atlas 40 soon.
xjeeper is offline
post #2 of 5 Old 06-28-2012, 08:15 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
In all honesty, I would just leave it at 48v and see how you like it with the FICM tune. I'm not entirely convinced my 58v upgrade did anything for me. You wont be able to monitor anything more than 50v anyways. JMO take it FWIW.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 5 Old 06-28-2012, 10:59 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I really like my 58v BPD FICM. I noticed a market improvement in throttle response and overall driveability. Not like a FICM tune but noticeable. And that was replacing an IDP moderate tuned FICM with just a 58v stock tuned FICM.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 5 Old 06-29-2012, 05:30 AM Thread Starter
xjeeper's Avatar
Thanks for the input, I may flip a coin between the 53, and 58 volt settings, I know that I can only monitor to 50 volts, but even if the 53 drops to 50 I am still ok, right now my FICM (that I repaired once, and Ford replaced once before that) is dropping to near 40 on cold starts, and running 47-48 when warm. I have the FICM paranoia, so a 6 phase BPD reading a constant 50 volts would be comforting. I have a fresh alternator, new Optima batteries and bumped my idle speed 50 rpm, and checked for any charge system voltage problems, I do not want any issues this coming winter, and I want another 100k miles from my stock injectors. All of these preventive upgrades are still much cheaper than a new truck (or the Honda Pilot my wife suggested that I trade for).
xjeeper is offline
post #5 of 5 Old 06-29-2012, 06:17 AM
Slacker
Evil Eye's Avatar
Quoted: 202 Post(s)
Feedback Score: 4 reviews
Congrats on the new purchase! Best of luck in whichever you decide, but it sounds like your FICM worries will be LONG GONE!!!! I've been running the 53v unit and it was a noticeable bump in performance, but I think based on how I use my truck the 48v unit probably would have been just fine. For those looking for a bit more performance, the higher voltage units would be ideal. Add to that, they are 6 stage, so you don't "lose" any reliability.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
