Y-Pipe to Turbo How too ????? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-19-2012, 05:30 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Got a leaking Connection, cleaned it up applied anti-seize started the 2 bolts, got the flanges almost touching, cinched it down put it all back together and it blows smoke.
If i go the other route, mount the Turbo to the Y-Pipe I can't get the front bolt started and fear it will cross thread.
Went to loosen the exhaust pipe bolts and they just spin, If I can only get the exhaust off the drivers side would that be enough to get the front bolts started with turbo almost snugged up?
I don't know what else to do at this point is there any secrets?
D
colonel angus is offline
post #2 of 16 Old 06-19-2012, 05:36 PM
Have you tried loosening the header to y-pipe connections that's how I do mine and I never have had a issue.
devster55 is offline
post #3 of 16 Old 06-19-2012, 05:41 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is one way to do it.
Oil cooler and EGR cooler service PDF files and notes
I like to have the exhaust manifold to y-pipe/up-pipes bolts loose hand started, then hand start loose turbo to pedestal bolts, then line up the turbo to y-pipe with a good even seal and tighten the mormon clamp. Then I go and tighten down the exhaust manifold connection, and finally tighten down the turbo to pedestal.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 16 Old 06-19-2012, 06:20 PM Thread Starter
Quoted: 2 Post(s)
Thanks, I'll give these a try before i decide to sell the freaking thing.
D
post #5 of 16 Old 06-19-2012, 06:22 PM
I get the turbo bolted in and then use a rachet strap from the passenger side head light hole and put the other end down between the two pipe. add some tension to the strap and then use a pry bar if needed and less than 5 mins it all done and tighted up...
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #6 of 16 Old 06-19-2012, 06:44 PM Thread Starter
Quoted: 2 Post(s)
Can this be done without taking it all out again? just loosen everything up as is? So your basically snugging it up tight to the turbo verifying the flange seats inside the turbo flange before sliding the clamp on huh.
May give this a try tomorrow nite.
Thx,
d
post #7 of 16 Old 06-19-2012, 06:49 PM
Beef52751's Avatar
this doesn't sound like a good idea to me, since the y-pipe flex joints are already notorious for leaking, putting them in a bind like that is asking for trouble
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #8 of 16 Old 06-19-2012, 07:32 PM
Yes if the gap is really bad I wouldn't do this but since mine is within 1/4" it's worked fine the last 25k with out issue. and I've had the turbo in and out a couple times.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 16 Old 06-20-2012, 02:48 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
I've never had to loosen the Y to exhaust bolts. I have always just left the turbo to pedestal bolts loose and put the clamp on the go back and tighten the turbo/pedestal bolts. I've had my turbo in and out a number of times and no problem.
RIP Mitch
the Org crew
PGreenSVT is offline
post #10 of 16 Old 06-20-2012, 07:12 AM Thread Starter
Quoted: 2 Post(s)
The frustrating part is i can make it touch almost flush maybe stands off 1/16" by itself, off a little to the drivers side about the width of the flange maybe 1/8" and can clamp the snot out of it and it will blow soot all the way around it like a Train stack.
Could the clamp be out of spec and no longer forcing the 2 halves together?
Denny
