Sorry, members but I have been thinking again and have developed a new turbo, it's sort of a stage 2. It measures 64.7mm/88mm but has a .58 a/r housing, it should perform well. This one is for testing and is not 100%, I need to find a way to get compressor wheel a better fit. I just hope it stays together, I was going to work on it more and make sure it was perfect, but since the dyno is coming and I needed it to get done for it the compressor wheel should atleast last that, untill I get one made the right way. You see the compressor wheel didn't quite fit the shaft and I had to pin it. Not the way I do things, but I'm under the gun to get this done for the dyno. If it works out I will have a new turbo, of course it will be do right for production. I might drop the stage 2 for this one it is easier to get built and it can be made from a stock powerstroke turbo. It will also lower cost of the stage 2. It won't flow as much air as the current stage 2 but will be close. This turbo would also work for 2.6 class since it measures at 2.55. If this one doesn't work I will be building another one that will have the compressor wheel fitted on alot better. I took some pictures of it next to stock, and a stage 1 so members could see the differance. I still have many more ideas to go, but I figure I would let everyone in on this one. Once I get caught up I have an exhaust I need to get started on, and I still have the manifold to due. This winter the my truck will be going down and I will be building a MAD TURBO WERKS TRUCK, I'm shooting for mid 700rwhp on fuel only and one vgt turbo. Thanks for everones support and I'll keep the mods coming, MADPOWERSTROKE
This picture shows stock opening, notice the belvell and no belvell on stage 2
This picture shows new stage 2 opening
