Head gasket question....... - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-09-2012, 04:55 PM Thread Starter
powersmoker1429's Avatar
So I noticed over the last couple days my coolant level dropped about half a inch on the bottle. No hissing or boiling out the cap. Truck don't smoke or smell Like coolant. Need some reassurance. Can't afford to do it again would be on my own. Thus thought scares me.
Thanks
powersmoker1429 is offline
post #2 of 22 Old 06-09-2012, 05:09 PM
ZMANN's Avatar
Quoted: 1456 Post(s)
the level varies a lot on mine but has a normal range it work within up and down
either cool outside /truck hot / or cool truck /hot outside
incline of truck ,, how long since I ran it ,, open the cap slowly it usually rises for Me
and just keep an eye on it for a while
We Miss you Ronnie
ZMANN is offline
post #3 of 22 Old 06-09-2012, 05:12 PM Thread Starter
Awesome thanks man.
post #4 of 22 Old 06-09-2012, 05:13 PM
jdman49's Avatar
i lost 4 gal over the weekend and one over the last 3 days i think my gaskets are gone it goes in monday for tests
no truck anymore. maybe next year.
"duramax was built just to keep ford tow trucks in business"
2 most import things to keep with you, Condoms and a handgun, never know when you'll be out and need protection.
jdman49 is offline
post #5 of 22 Old 06-09-2012, 05:17 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
An easy way to tell if you have head problems is to do a pressure check on the coolant system and see what it's at.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 22 Old 06-09-2012, 05:42 PM
jwsland's Avatar
While driving/running for an accurate reading correct?. You can still hold 16psi at the bottle with blown gaskets sometimes. Also, my mechanic was telling me that the headgaskets reseal themselves after the truck is running and sometimes won't show common syptoms of a leak. (I may have worded that wrong) As in my case my truck would pour white smoke at startup the first 30secs of driving then clear right up. Thats the coolant that leaked in the engine buring off then the gaskets sealing back up. I could crack my degas bottle cap at night to release the pressure and the truck wouldn't smoke the next moring.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #7 of 22 Old 06-09-2012, 06:03 PM Thread Starter
Yeah mine don't smoke at all or even smell like coolant or any residue on the cap. In thinking air lock/. Kinda doubt the hg now since I got studs
post #8 of 22 Old 06-09-2012, 06:21 PM
This thread couldn't be more timely. I did an EGR delete and a high flow internal cooler. The truck has been fine....no issues...temps at 190 to 200 on the coolant and within 2 to 10 degrees for the oil. I towed my big trailer....the whole rig weight 20,000 lbs...drove maybe 45 min....temps never went over 220. Next day.....no load...no trailer...now its running 220 on the coolant and oil....no evidence of coolant being pushed out of the cap and no smoke...ever...
So?? thoughts?
spinto is offline
post #9 of 22 Old 06-09-2012, 07:32 PM
jerg_064's Avatar
The coolant level definitely varies alot....I've also found that it'll slowly rise about an inch after shut down too.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #10 of 22 Old 06-09-2012, 07:37 PM
could i assume that my level was low to begin with?? or there was some air??
spinto is offline
