stock cooler & piping -vs- Banks cooler & piping on my truck - Ford Powerstroke Diesel Forum
Old 06-08-2012, 01:28 PM
Ok well I wanted to get a before and after so I took some readings today on my stock setup and since we have a few days of good weather I'll be swapping out the stock stuff and installing the banks cooler setup to see the difference. BTW I have the mods listed in my sig and my EGR is turned off.
Stock 2 readings I saw over a 20 mile drive
IAT1 = 84*F / IAT2 = 125*F
IAT1 = 86*F / IAT2 = 129*F
Once I get the Banks installed I'll update this.
Old 06-08-2012, 01:32 PM
Turbos = Witchcraft
This should be interesting. Can you also give us your thoughts on how throttle response and spool up have changed if at all.
Old 06-08-2012, 01:48 PM
Yes, I will Thats why I did the PM before the cooler. I also had Eric@IDP update all my tunes for the PM so I should be good there. I'm also getting a mileage reading with the PM and then the PM with the cooler over my stock setup.
Old 06-08-2012, 01:58 PM
Slacker
Feedback Score: 4 reviews
Cool! I can't wait to see the results.
Old 06-08-2012, 02:10 PM
Im interested in the spool time difference. Once the turbo lights the flow will be much much better for the engine and turbo. But the lerger pipes and intercooler add volume.
Old 06-08-2012, 03:45 PM
In for the results.
Old 06-08-2012, 03:50 PM
The Silent Service
Watching for the results here, good idea to get the before and after numbers.
Old 06-08-2012, 04:00 PM
Yea I wanted to get before and after on the turbo temps from stock to PM but I may do that at a later date when I get a wild hair. My big thing even more than EGT's was to watch air temps before the turbo and after the turbo and cooler.
Old 06-08-2012, 06:49 PM
I Love Workin On Hotrods
Got any WOT run EGT numbers to see if it does anything for those??
Old 06-09-2012, 03:08 AM
Here is what I have so far for the same type of WOT run I normally due which is 10mph role then straight to WOT hold till I through the gears.
stock IC and stock turbo : 1370*F~
stock IC and PMax turbo : 1280*F~
