More Airdog ?'s
I was going to order one today but got confused when every online parts dealer told me something different. The truck has stock injectors for now someday I'd like to upgrade. I was planning on buying an AD 150. I was told I need a 165 by one shop another said 100 is plenty. One of the kits eliminates the stock pump/ regulator? I'm guessing a need a "quick connect" model. I was also told I do not need a sump.
Just wanted to see everyone's opinion on which Airdog to buy. I was going to buy a crossover line (dfuser kit) and get my banjo bolts as well. I wasn't planning on getting a reg return kit. I'm pretty much trying to prep for injectors since my truck is completely torn down right now and I'd like to get the small stuff out of the way. |
The AD165 is the one that eliminates your stock fuel pump and has a built in regulator. That's what I got and I haven't had any problems out of it. Although most people recommend a sump and I do plan on getting a sump soon. If you decide 165 over the 150 then you might want to skip the regulated return. I've heard there's no need in having two regulators in one system, but that's all matter of opinion.
I prefer the ADII DF-165 and eliminating the stock fuel system. Either way you go I highly recommend that you feed it from a sump. Your pump will be much happier if it only has to push the fuel to the engine. If you do a 165 block off the fuel return line from the oem filter can and let ADII regulate the system.
I recommend you go with the AD2 165 with the built in regulator, when i had mine with out the sump i would loose pressure when i was under 1/4 tank and that isnt good on the pump or the injectors at all. After the sump i havent had the problem once. If you plan on going with larger injectors down the road I also think you should get a regulated return, the crossover line wont help much. As long as the pressure on the AD2 is set higher than the pressure of the RR you will not have any issues. That is how i have mine setup with 190/100s and it works great, i also did a fuel bowl delete while i was doing my build. Have you looked into an Aeromotive (A1000) instead of an AD2? I plan on getting rid of mine and switching over to that.
Ordered the AD2 165 with a sump. Opted out on the fuel lines/crossover. Thanks for the info guys!
Good move. No need for the crossover and the ADII is already a regulated return. Just block off the oem fuel return line when you install and you'll be good to go.
Where do I need to block off the return line? Is that from the fuel bowl on the motor or under the truck where that "y-shaped" pipe is that comes with the AD2 to go in place of the HFCM? Sorry if this is a dumb question
Thanks Lilpooh, I was just about to post that.
Thanks guys. I'll get that blocked off ASAP.
