s & b intake? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-31-2012, 08:04 PM Thread Starter
s & b intake?
i was plannign on purchasing an intake system for my 6.0 i have read a few threads on here to find out what people are liking, and as of right now i am looking at an s and b intake with a high flow elbow. i am just wondering if i would be making a good purchase an not just wasting my money.
waterfowl1989 is offline
post #2 of 17 Old 05-31-2012, 08:22 PM
Dirty_Stroke's Avatar
Your going to get mixed opinions on this. Some people claim no difference at all and it was a waste of money and others claim mpg and throttle response gain. I think all trucks are different and its hard to say if you will notice a difference or not.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 17 Old 05-31-2012, 08:42 PM
ssdeuce's Avatar
it definately makes a difference towing normal driving i don't notice so much.
I MAY BE CRAZY BUT I AIN'T DUMB
04 F250 6.0 FX4 CC SB
S&B intake
CFM+ INTAKE ELBOW
4" TURBO BACK STRIAGHT PIPE NO CAT
SCT W/ VIVS TUNES
ZOODAD MOD
SUPERCHIPS DUAL LAZER GAUGE (EGT&BOOST)
ford blue spring
banjo bolts
and heck its my slowest vehicle
gotta work on that
ssdeuce is offline
post #4 of 17 Old 06-01-2012, 05:05 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I like my S&B and wouldnt run my truck without one. I had the AFE stage 2 and it was nice but I like the S&B better. I dont think they are a waste of money.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 17 Old 06-01-2012, 08:07 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Numbers don't lie ...S&B doesn't hold up for the long haul. Expect more maintenance in the long run.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 17 Old 06-01-2012, 08:13 AM
Turbos = Witchcraft
TooMuch03's Avatar
It depends what your goals are. S&B is one of the best aftermarket intakes out there. If you just want a reliable, low maintenance truck (why did you buy a 6.0 ) then stick with stock. It will flow enough and hold lots of debris so it filters great without being changed a lot. If you want better performance, mileage, and don't mind tinkering with the truck, I say buy it. There is NO question that it will flow better than the stock filter and filters almost as well, but it will need to be cleaned or replaced more often.
BTW the stock filter is a PITA to change, so it may be worth it just for the ease of maintenance.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 17 Old 06-01-2012, 08:17 AM
N.S.D.Q.
Quoted: 97 Post(s)
S&B will clog faster therefor flow LESS than an OEM filter for the same amount of dirt/dust. Less flow results in POOR performance and MPG.
Modifying the OEM intake is easier, cost less and achieves more than any any aftermarket intake could EVER.
post #8 of 17 Old 06-01-2012, 08:21 AM
N.S.D.Q.
Quoted: 97 Post(s)
Cut down as much as you want....the more you cut the bigger the hole will get. Makes OEM filter swaps take less than 5 mins.
post #9 of 17 Old 06-01-2012, 08:37 AM
DoubleDpsd's Avatar
I like this idea, I just took the entire front cover off. Personally, I don't think the piping that comes with the afe or s&b is worth the money. Im gonna put a drop in airaid filter into the stock airbox. Jmo.
Sent from my droidx using autoguide app
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #10 of 17 Old 06-01-2012, 08:52 AM
ssdeuce's Avatar
my afe didn't get good maint may have cleaned it once a year but still had better mpg, also even when a bird made a nest in it i did feel the difference but my turbo was still perfectly clean inside with no sign of damage on the wheel no brainer for me. i have the stocker on now and w or w/o the front it doesn't perform as well or get the mpg. can't wait for my s&b to get here monday.
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
