Fuel sump + airdog2? - Ford Powerstroke Diesel Forum
Old 05-31-2012, 04:10 PM
Hey guys! So I just ordered an airdog2 and a no drop sump I'm going to be doing the install on my garage floor most likely at midnight with drunk buddies watching .... Sooo is there any parts/special tools that I should have ready that don't come with the kits? Another question is will i have to drop the tank at some point for this install?
Old 05-31-2012, 04:33 PM
LOL....not dropping the tank could leave drill shavings in the tank. I dropped mine, did the sump, and thought I got all the drill shavings out. NOT....drop the tank and CLEAN it out. Stay sober or face spending more money....$.02
Old 05-31-2012, 04:36 PM
I Love Workin On Hotrods
I think you will have to drop the tank for the AD2 install if you dont lift the bed up. I don't know for sure though. I know when I installed my AD150 I had to either drop the tank or lift the bed up. A word of wisdom if you drop the tank, make sure you have less than 1/8th of a tank in it, otherwise it will be a pain for you to get back up in there. Hope this helps.
Old 05-31-2012, 04:40 PM
YOu dont have to drop the tank or lift the bed for the AD2.. Its a pain in the a$$,, but can be done.. I didnt drop the tank when i installed mine...
Old 05-31-2012, 04:41 PM
Well I would be the sober one doing the work lol ... But the fuel line that comes with the airdog will be fine to go to the sump? I won't have to buy any additional lines or fittings?
Old 05-31-2012, 04:46 PM
I dont know. It depends what size barbed fitting came with your sump and what size the fuel lines are on the AD2. I know the fuel line on my AD150 is 1/2in ID hose and that is the size of the barbed fitting that came with my sump that I plan to install but I dont want to say that that is how it is for your setup if you know what I mean.
Old 05-31-2012, 04:57 PM
I got ya windrunner ... I can't find the sizes on the website so il just wait untill I get them here but the sump is the xdp sump, forgot to put that in the thread ...thanks for the quick responses guys
Old 05-31-2012, 04:58 PM
Ok well I also have an XDP sump so if your hoses are 1/2in, then yes they'll work.
Old 05-31-2012, 05:05 PM
Perfect ! What did you do for a fuel pressure gauge, or plan on doing? I have the edge cts and it looks like its going to be expensive to monitor fuel pressure on that
Old 05-31-2012, 05:19 PM
That is how I monitor my fuel pressure and yes it is expensive but I went ahead and bought two pressure sensors so I could fully use my universal sensor input and I also monitor actual oil pressure. It is worth it to me. JMO.
