Gear oil selection - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-31-2012, 10:44 AM Thread Starter
smokersteve's Avatar
Quoted: 19 Post(s)
Gear oil selection
Its my neighbors 04 2004 dually Manual Transmission.
This is the tag for the rear diff. Dana 80 right? Am I also correct that it takes 75W-90? If so then I would like to use amsoil.
AMSOIL Synthetic Gear Lube - Gear Oil
And for the manual 6 speed. What oil do you recommend. How often should it be replaced?
AMSOIL Synthetic Automatic and Manual Transmission Fluid
Thank you!
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #2 of 10 Old 05-31-2012, 11:23 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Looks like a dana 80 to me. As far as what oil is recommended for what I would look the truck up under Amsoil's "Auto and Light Trucks" Product lookup guide. It will have both the type of oil to use in each part and the capacity of each part.
2004 FORD TRUCKS F350 PICKUP 6.0L 8-cyl Engine Code [P] Turbo Diesel - AMSOIL Online Product Application Guide
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 10 Old 05-31-2012, 11:32 AM Thread Starter
Quoted: 19 Post(s)
I used that. It states 75w-90 and 110. So thats what Im wondering. Its surpising cuz my f-350 takes 75w-140, I thought it would be the same.
And it also gives me the 2 options for the manual trans.
FICM Testing Videos
post #4 of 10 Old 05-31-2012, 11:37 AM
BACKYARDIGAN
Quoted: 4 Post(s)
I got ya man. Yea it has all to do with the different housing types. Your F350 (like mine) is a SRW with a Sterling 10.5 rear end and that requires the 75-140 where the dana 80 (like the dana 60) can take the 75-90. I would stick with what they recommend in the first of two listed for the dana 80. JMO and hope it helps.
Nate
post #5 of 10 Old 05-31-2012, 11:55 AM Thread Starter
Quoted: 19 Post(s)
Ok then I will get the 75W-90 for the rear.
What about the manual trans. Which amsoil fluid would be best?
FICM Testing Videos
post #6 of 10 Old 05-31-2012, 12:13 PM
BACKYARDIGAN
Quoted: 4 Post(s)
This is what they recommend you use.
Nate
post #7 of 10 Old 05-31-2012, 12:17 PM Thread Starter
Quoted: 19 Post(s)
Ok, thanks for your help Nate
FICM Testing Videos
post #8 of 10 Old 05-31-2012, 02:00 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Yea man any time. Happy to help.
Nate
post #9 of 10 Old 05-31-2012, 06:57 PM
strokin6L's Avatar
Quoted: 3 Post(s)
i have different weights of oil in the rear and front. Both axles have royal purple....one has 75w-90 and the other has 75w-140.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #10 of 10 Old 05-31-2012, 10:53 PM
grayweber24's Avatar
In my 10.5 LS I used redline 75w-140 w/o modifiers. Then got some friction modifier from the dealer. I only had to add 3 oz to stop the chatter, and now my truck preforms so much better offroad. Night and day difference.
grayweber24 is offline
