Help with exhaust leak - Ford Powerstroke Diesel Forum
Old 05-29-2012, 07:45 PM
I have a 4" MBRP Turbo Back exhaust that I have no complaints with except for one small thing. The down pipe flange will no seal with my CAT flange. I have cleaned the CAT flange, removed the studs and use bolts, the flanges just don't mate flat. The cat delete pipe I have matches up perfect, but living in San Diego, I have to keep my CAT and would like to figure this out.
He is short video showing the gap at the flange and a small leak. Any ideas?
exhaust leak at cat flange - YouTube
Thanks
Dik
Old 05-29-2012, 07:53 PM
Dump the gasket and just use RTV high temp gasket maker. I used to have the same problem
Old 05-29-2012, 08:02 PM
What did you use and how does it hold up? My EGTs are around 600 at hiway speed.
Dik
Old 05-29-2012, 09:34 PM
High temp RTV silicone. It's held up fine for a few years. Had to replace it again at the beginning of the year because I moved it. Got it from Auto Zone.
Old 05-29-2012, 09:35 PM
Thanks
Dik
Old 05-29-2012, 11:38 PM
Ultra Copper hightemp RTV sealant.
