Cts insight questions! - Ford Powerstroke Diesel Forum
Old 05-29-2012, 10:04 AM
Can anybody clear a few things about the cts lol im lost
- can you set defuels? At certain psi for boost and egt?
- what's safe egt and eot and ect and boost ?
- And what should they be at in a normal situation.
- I have arp head studs and mkm Egr delete everything else is stock.
Thanks !
Old 05-29-2012, 12:09 PM
Feedback Score: 7 reviews
i never set anything on mine but i know you can set warnings. im not sure if you can get it to defuel the engine when temps get too high. there isnt too much that can hurt your engine with everything deleted and studded, hopefully someone can chime in with what your looking for.
Old 05-29-2012, 12:13 PM
Almostdunfukinwidit
CTS wont defuel. You dont want it too anyway.
Safe EGT is 1250 max sustained
boost varies with tuning.
ECT and EOT should be within 15 degrees of each other cruising unloaded at 60mph
Old 05-29-2012, 12:23 PM
no and nope
under 1300 constant and as long as difference between ect and eot is less than 15, you are ok. but eot needs to be lower than 230.
Thanks !
cts is a reader only and a code reader and removes codes.
Old 05-29-2012, 06:29 PM
Okay thanks alot what's safe or " normal" ect and eot numbers ?
Old 05-29-2012, 06:31 PM
I Love Workin On Hotrods
Normal ECT numbers are 188-192F. Norman EOT is within 10F of that.
Old 05-29-2012, 09:00 PM
Awesome Thanks ! Any suggestions of what pids I should watch?
Old 05-30-2012, 04:04 AM
Eot, ect, TFT, ficm v, Egt, and the rest is up to you lol.
iPhone
Old 05-30-2012, 04:12 AM
Lol thanks
