intake manifold cleaning gone wrong - Ford Powerstroke Diesel Forum
Old 05-28-2012, 09:46 AM
Im trying to clean my intake. I soaked it in degreaser overnight not even thinking about the annodized aluminum. Now its all black and powdery. What do I do now? The inside is not that clean, and I really dont want to polish it all off. I was thinking about just painting it at this point. Any suggestions?
THanks Chris.
04 6.0L
Old 05-28-2012, 09:54 AM
Feedback Score: 3 reviews
I don't think the intake manifold is anodized, it's raw cast aluminum. What was the degreaser agent you used?
Old 05-28-2012, 09:55 AM
Purple power, purple something. it was from homedepot in the 5 gallon jug.
Old 05-28-2012, 10:28 AM
I Love Workin On Hotrods
Yea these manifolds are cast and not anodized. I'm not really sure what to tell you to do on this one.
Old 05-28-2012, 10:42 AM
Pressure wash it.
Old 05-28-2012, 10:49 AM
Originally Posted by PGreenSVT View Post
Pressure wash it.
The Victor Jr on my hot rod took a ride through the machine shop's parts cleaner and came out with this grey/black film on it, probably what yours looks like. Anyway, I used a spray cleaner from "Circle K" auto parts that worked just fine. I think it was a wheel cleaner.
Might be just as easy to use the de-greaser setting at the car wash (the local on here is SImple Green) then pressure wash it. I'd be pressure washing the insides anyway after spending the night in solvent.
Old 05-28-2012, 12:43 PM
Take a pic of it
Old 05-28-2012, 02:37 PM
is it just the carbon that broke loose? if it wont come of i would think you could hit it with some aluminum brighter acid or some aluminum wheel cleaner let it sit for 30-1min no longer and powerwash it off repeat till you get the look you desired just dont let it sit on for no longer then a 1min
Old 05-28-2012, 05:44 PM
Thanks guys the pressure washer did the trick
Old 05-28-2012, 06:16 PM
Purple power is good non toxic cleaner, even thou it says keep away from painted surfaces I dilute it and use it to clean all sorts of stuff, and you don't get in trouble if it gets in the drain and it won't kill the grass.
