custom tune and sensor accuracy ? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-27-2012, 11:45 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 40 Post(s)
Do custom tunes cause the overhead temperature readings to be off.? The reason I ask is because I noticed my overhead temperature is reading about 6 degrees warmer then the outside temp,also my cts IAT is reading the same as the overhead.Would'nt this cause the pcm to get the same info maybe causing the truck to run differenty?
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 2 Old 05-27-2012, 02:13 PM
my ambient air temp sensor has always been about 2 degrees colder than what is and since its been custom tuned i have not noticed anything different, i think my moms camrys sensor is off by 5 or 6 degrees, i think its just the sensor goofs like the lie-o-meter for your mileage
2007 lariat outlaw
ARP studs
egr delete
4inch mbrp
tunes from gearhead
atlas 40 ficm tune
zoodad mod
ccv reroute mod
strokedoutlaw is offline
