Fuel System upgrade
I'm overseas again making some extra cash to upgrade my PSD. My next big job will be upgrading the ful system, I been thinking in the Driven Diesel 6.0L Regulated Return Kit, AirDog II system and Sinister Fuel Tank Sump Kit.
Anyone using this kits? And what else is recomended for the fuel system? |
If you get the AD2, you could just scratch off the RR kit. I guess it all depends on what you want to do with your truck as far as larger injectors go. I personally would scratch the AD2 and get an AD150 to feed your stocker, use this sump you mention here, and get a RR kit from either Strictly Diesel or Dozer's Diesel. JMO and hope it helps.
Yes there are a fair amount of combinations to do and most work well. Just search the forums and chose the flavor you prefer. For me I chose an AD2, larger fuel lines, fuel sump, RR (which I built myself so it only cost me the price of the regulator and my theory was to keep a higher flow going thru the AD2 thinking it will live longer), dumped the OEM pump and engine mounted filter.
I run the ADII, sump, new fuel lines eliminating all of the oem fuel system. I let the ADII regulate the system with no other regulator involved. Works great.
Later upgrade will be bigger turbo and bigger injectors.. |
My 2 questions for you, first do you have photos of what you did for the lines in the engine bay, and did you run lines to the back of the heads. and two what do you have your pressure set at on the AD2? |
Your wife must love truck parts in your living room. LOL
Yeah not happy. lol But i have truck parts all over the house, my trophy pieces (piston, valves from when i dropped a valve) are sitting in our room
Minor fuel economy improvement with only a couple psi drop at WOT. I've had zero issues with mine and know a lot of guys that have a similar setup that also have had zero issues. I know the early AD2 version seemed to be questionable in some setups. As I've stated before, my only reason for even putting a RR was to maintain a consistent flow rate thru the pump from idle to highway driving and when compared to the same year engine and setup without the RR my pump was noticeably quieter. This may or my not be related to my setup IDK. I just know at work our huge positive displacement pumps that last the longest are the ones with a fairly flatline flow going thru them and the ones that are internally regulated only (similar to the AD2) have a higher failure rate. Just a theory mind you, but one that seems to be working out so far for me and a few guys that have the exact same setup.
