Possible AIRDOG2 issues need some help
I have been running an airdog 2 for a year now and not had any issues till tonight and still not sure it is the pump. I was driving home tonight and noticed my fuel pressure gauge was jumping from 66psi where I have it set , to 56 psi. I was on the freeway going about 70 when I noticed the gauge went to 50psi and then completely went to 0 and no movement at all when I let off the pedal or not. I pulled over and shut off engine and ran my edge CTS to see if any DTC popped up and none did. I turned it back on and it turned over with no problems at all but gauge was still not moving. I drove home and still noticed no difference in performance. When I got in town at a stop light it felt like it was looking for fuel ONE time. When I parked at home I noticed my pump was not making the same hum or noise I am used to when it is pushing fuel.. If my AD2 is either going out or not working properly would my truck still drive, turn over with no problem or is the engine sucking fuel from tank and I may be starving my injectors?
Sounds like its on the way out. Of the AD and FASS pump failures I've seen almost all of them were permenantly fixed with a fuel sump.
Low profile fuel sump |
I have power to the pump and the fuses are good but when I feel the pump motor I feel or hear it moving... My truck turns over no problem and idles like normal.
Contact Pure Flow with your problem they have a good customer service.
Do you still have the oem FPR in your fuel system? If so I highly recommend you disable it by blocking off the fuel return from the FPR. Also these systems are greatly aided by a sump rather than drawing from the top of the tank.
Sent from my Droid using AutoGuide.com App |
I removed the fuel pump when I installed the airdog. To make sure I understand where the FPR is can you give a little more insight? |
The OEM FPR is behind the "T" shaped metal block where the fuel lines connect to the engine mounted filter assembly. #27 Torx
What benefits would I get from blocking off the OEM FPR?
The AD2 is self regulated so the really is no point having a second regulator (the OEM one) doing the same job. IMO not deleting the OEM regulator can reduce the reliability of the AD 2
Yes, I believe eliminating the oem fpr will help the ADII reliability by not forcing it to run at higher pressure than necessary because of the extra FPR.
This is where you block the oem fpr by inserting a blocking disc.
