opps am i up **** creek - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-24-2012, 07:52 PM Thread Starter
hagemasta's Avatar
Unhappy opps am i up **** creek
i seemed to have lost my sct programer and I had my stock setting on it. Did not save it on the computer stupid me. Right now i have a tune downloaded in my truck. my ? is can i buy another sct to download tunes in my truck with out the stock setting or am i up **** creek. need help
hagemasta is offline
post #2 of 11 Old 05-25-2012, 03:07 AM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
The new SCT will recognize the vehicle's tuned, if memory serves, which will prevent you from tuning it again. If I am wrong someone may chime in there.
If it would me, I'm first make sure my old programmer isn't simply misplaced, because what I'm going to recommend is going to suck some mileage out of the truck. You are going to either find a Ford dealership to reflash the latest strategy on your truck (which will give you a CEL with ECT/EOT is out of spec by Ford's standard, cycle turbo vanes at idle, and drop your gas mileage a bit), or you need to find a shop that can reflash you with an earlier strategy (the earlier the better, there's some threads on which of these early strategies are preferred).
Then have new tunes written for the newly flashed strategy. You won't be able to use any of the custom tunes you had earlier, due to they are locked to the previous SCT serial number.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 11 Old 05-25-2012, 05:04 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Just give SCT a call and ask them. But seeing how they strongly recommend backing up your stock tune to your computer, you more than likely need a flotation device...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #4 of 11 Old 05-25-2012, 05:46 AM
rebelranger's Avatar
What is your current strat? Maybe we (the .org) can send you a stock strat and you can tune your truck with it from your new SCT tuner if it will let you. I have one I can send from an 05 with the VXFC9
rebelranger is offline
post #5 of 11 Old 05-25-2012, 05:52 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
This is actually a good idea (I think). I would be more than happy to send my stock file to you. It is actually a good strategy VXCF4xx. I am just not sure if it would work with an 04 truck because only certain strategies (if I am correct here) will work with certain years.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 11 Old 05-25-2012, 05:58 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You might be able to buy a new tuner from a SCT tune writer and explain the situation, if you happen to remember the strategy hex code, they might be able to send you a stock file thru email, and either the tune writer or SCT can set you up with a recovery file to pull out the custom tune and load in a stock tune.
The other option is have the dealer reflash or contact PHP about having getting a stock file and rolled back. With PHP there is a waiting list for the remote programmer, or you can send in your ECM to PHP to reflash/roll back.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 11 Old 05-25-2012, 06:00 AM
Powerstroke Techie
Lilpooh's Avatar
He will still need to contact SCT for a recovery file that allows him to pull off the stock file from his PC to the SCT device.
Lilpooh is offline
post #8 of 11 Old 05-25-2012, 06:01 AM
onealmx11's Avatar
Quoted: 175 Post(s)
What about power hungry performance, they reprogram pcms with earlier strategys.
onealmx11 is offline
post #9 of 11 Old 05-25-2012, 06:12 AM
xjeeper's Avatar
Call Bill at PHP and sign up for remote pcm rollback, you can do FICM at the same time if you want.
xjeeper is offline
post #10 of 11 Old 05-25-2012, 05:18 PM
jwsland's Avatar
I forgot to return my old truck back to stock after it was totaled and had a locked sct. They unlocked it for me for free so I could use it on the new truck. They have good customer service, try calling them.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
