airdogII and stock filter - Ford Powerstroke Diesel Forum
Old 05-24-2012, 05:12 AM
Question airdogII and stock filter
ok do u have to run the stock fuel filter on top side if u run the airdog II? if not how do u bypass it?
thanks
Old 05-24-2012, 06:14 AM
No you do not have to run the stock filter in the top fuel bowl with an AD2. You simply take the filter out, but make sure to also take the plastic stand out of the middle of the bowl too or it will not flow properly. I've been running without a filter for 6 months with no problems.
Old 05-24-2012, 06:48 AM
OK THANKS I DIDN'T TAKE THAT STAND OUT OF IT JUST TOOK THE FILTER AND IT WOULD NOT RUN RIGHT SO I'LL TRY TAKING THAT STAND OUT AND TRY IT .
THANKS
Old 05-24-2012, 07:01 AM
Another thing i was wondering y they run 1/2" hose from the tank and a little after the pump but tie in to the stock lines after the old filter. seems like it would b no diff than running in the the stock line the hole way. just my thinking tho. mean nothing by it just wondering.
Old 05-24-2012, 07:08 AM
I'm not sure why they do that. I've seen several people that have done away with all the stock lines and stepped up to bigger hose all the way. You can also delete that filter housing all together. I believe it was Windrunner that had a thread not too long ago about deleting the fuel bowl.
Old 05-24-2012, 07:39 AM
Good to know info as my airdog2 is sitting in my livingroom awaiting install.
Old 05-24-2012, 01:50 PM
Yeah, a bunch of us have completely re-plumbed the entire fuel system eliminating all of the oem fuel system. 1/2" from tank to pump, pump to engine bay, split to dual 3/8" to the banjo's. Very common.
