Questions about the Edge CTS Monitor...Can you hook up a turbo timer to it? - Ford Powerstroke Diesel Forum
Old 05-13-2012, 02:45 PM
Hi, my first post
I have an 06 6.0 with 80K miles on it and it is all stock. Before doing anything to it, I have decided to go with an Edge CTS monitor. Reason I like it is because of the expandability options which I intend on using.....The back up camera, the gauges with alarms, the maintenance manager, and of course the EGT probe to be used with the turbo timer. My questions are whether or not you can use the EGT probe/turbo timer with the monitor (not juice or tuner or attitude or whatever)
One off the topic question: Is there any easy way to tell if head studs have been installed?
Old 05-13-2012, 04:05 PM
Edge sells a turbo timer for the CTS, just check out their site.
On the other question, if you look down on your heads you will see the bolts there. I think there are pictures on the site showing the difference.
