OK here it is,and if anyone wants to debate it it's ok,I was waiting for Dyno numbers to add to the fact.Now I was hoping for 500rwhp and little over numbers and yes they are possilble with stock injectors,due to two things.One the FICM tuning to get every drop out of fuel needed out of the injectors,and two air and lots of cool dense air(not boost psi).
SHOCKER FOR DIESEL WORLD::::I have done alot of research and so here it is,DIESEL's love air the more air you can pump in the better,cool dense air,they will make crazy power and burn very effiecent.Diesel unlike their gasser counter part run better on air,diesel fuel has a very low detonation limit,if fact if one gets gasser to 15:1 ratio(15 air to 1 part fuel) which is limit for fuel without detonation,where diesel's run at idle as much as 50:1.If you hit 20:1 than rich back soot comes out of the exhaust,and EGT go hand in hand with it.So that's the shocker fuel should be used little as possilble and air used as much as possible.Not only do you get Power,low emissions,low egts and better fuel economy,just look at the threads here on a 03 daully getting 25-26 mpg at 70mph on freeway.(more air)My friend widrunner408 used this example and I liked it The simple truth is that diesels LOVE air more than they love diesel. Everyone thinks you have throw more diesel to get horse power but what is NOS?? NOS is nitrogen and oxygen. Nitrogen is inert (therefore does not burn or make power) and Oxygen is what causes the boom (so to speak) with diesel and guys can easily spray to over 500hp with stock injectors and all they are doing is adding in A LOT more Oxygen. Well a turbo can do something similar with more air. And what makes up air?? Nitrogen (~79%), Oxygen (~20%), and Argon (~1%). Well Nitrogen and Argon are inert (therefore dont burn and make power) and like NOS, compressing more air will put in more Oxygen and cause a cleaner burn, which means more CO2 is produced as opposed to CO (black smoke), therefore creating MORE POWER
Ok well that is text book answer. What no kidding is going down to make this happen is the Stage 2 simply flows A LOT more air than the stock turbo AND with a high performance tune (like the Looney or SPD or Xtreme X or ) AND PHP's Hercules FICM tune, you get just about every drop of fuel you can out of the injectors and into the cylinders, which is A LOT more fuel than is being delivered with stock ECM and FICM strategies; and BAM the motor starts making HIGH horse power numbers compared to stock.
So in summary you shoot in a sh!t load of air with ALL of the fuel that the stock injectors will flow and there you have it, a ~490rwhp ~970ft-lbs truck. Hope this helps explain it a little better for ya.
I will be breaking the 500rwhp very soon with this type of thinking and hope other turn their efforts to this way of thinking.As far as I'm concern I didn't invent anything,I took the knowlage that was out there from the diesel experts and used it to see what would happen and you are seeing it.I have developed new turbos that flow alot of air to support all this new way of thinking,and there will be alot more to come.I hope you guys enjoy the ride because I'm here to shock the diesel world and change the old way of thinking into a better way.What's next I plan,on running the 175/75 injectors with the new MAD stage 3,and sqeezing every bit out of the injectors to put down over 600-650rwhp,sounds impossilbe not so much you'll see,it the new way of thinking.Thanks MADMAN
