blow off valve reduce boost at speed? - Ford Powerstroke Diesel Forum
Old 05-09-2012, 01:17 PM
ive been pondering the thought for awhile now about putting a blow off valve on the truck to see if at cruising speed ay 75mph i can lower the boost down around 4psi or even lower to help with fuel economy.
i know on my cars as long as u stay out the gas hard u can cruise with little to no boost at all.
i do realize the trucks are heavy ect.. but they still should make enough power NA to push its own *** once its up to speed without pulling......
has this been done or attempted yet ect...?
Old 05-09-2012, 01:28 PM
no
first off there is no throttle body to create the vacuum you want to vent the BOV. And believe it or not the extra air is probably helping fuel as you are getting a more complete burn. Coming from someone who is huge turbo'd the truck out of boost at 75 is a dog and actually runs higher EGTs without the air.
i have tried this theory when i was stock turbo by flipping the smoke switch, which basically opens the turbo all the way up, and would drop psi as much as 6 psi cruising and had no improvement in mpg, made it harder to drive and smoked a hell of a lot unless you are going to reach up and keep flipping the switch on and off.
if you want fuel economy do the mods:
exhaust, egr delete, tunes and drive slower. these trucks start to drink fuel at 70+ sadly i drive like you as i live in atlanta and 285 means you get crushed if you do less than 70. but if i drop rpms below 2k and even around 1800 which is about 60-65 the mileage increase is surprising.
Old 05-09-2012, 03:04 PM
a BOV will only stop the surge(turbo fart) from when you suddenly let off the throttle...that's it.
Old 05-09-2012, 04:13 PM
why would you want to use less air at 75? the air from the turbo keeps you from chuggin the fuel right out your tank, i just got back from a 300 mile trip and i ran bout 8-11 psi at 75 and was running about 680-715 egts and got 18mpgs the best i have ever gotten
Old 05-09-2012, 04:33 PM
this is a diesel
Old 05-09-2012, 05:40 PM
diesel= more boost is better
Old 05-09-2012, 06:33 PM
BOOOOOSSSSSSSSTTTTTTTTT
Old 05-10-2012, 04:06 AM
actually i always run at 80 mph.... as i drive about 1.5-3 hours a day sometimes the turnpike ..
i guess it could possibly work with a actual tuner on the truck so u can lower the fuel as the boost goes down .. but not so sure..
seems to get ok mileage.
i still get 4-5 days out of one tank & that includes city driving, just trying to squeeze little more out.
thx
Old 05-10-2012, 05:48 AM
thx
LOL...what? Please dont tell everyone that you actually think that a BOV works as a tuner. Do you have any clue what a BOV does or is suppose to do?
Old 05-10-2012, 06:28 AM
thx
The more boost you have at speed means the harder the truck is working reducing the about of boost it sees will make the truck run with less air meaning it wont work as efficient. So the amount of boost is the effect not the cause. wanting to reduce the boost is not what you should be doing.
Also you will get the best mileage in your hottest tune. your truck will have more power so it works less to maintain your speed. It will also have lower boost (while at speed not WOT) in your hottest tune because it is working less.
