Edge or bullydog - Ford Powerstroke Diesel Forum
Old 05-08-2012, 07:02 PM
Edge or bullydog
I'm going to be buying a monitor. For 2004 f350. Wondering if any one knows if product will see all data possible without having to add a bunch of accessories. I know I need pyrometer for egt's, but anything for other data?
Old 05-08-2012, 07:08 PM
Feedback Score: 3 reviews
Might as well go with the Edge Insight CS/CTS, their are parameters that the BullyDog won't read. Like FICM.
Old 05-08-2012, 07:38 PM
I don't see ficm on list of parameters on website . Are they calling it something else?
Old 05-08-2012, 08:38 PM
6.0L Powerstroke
Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Pressure, Engine Oil Temp, Engine RPM, Engine Run Time, FICM Voltage, Gear with TCL, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle
2 stroker
Old 05-08-2012, 08:54 PM
Wow. Cool man. Thanks good info
Old 05-12-2012, 07:30 PM
Just bought insight cts with pyrometer . Where exactly should I install egt sensor for best/most accurate readings?
Old 05-12-2012, 07:33 PM
Manifold on driver's side.
Dieselmanor has good install instructions for gauges, but shows the EGT part too.
Old 05-13-2012, 11:31 AM
Goes in the bend in the manifold. About a 30 minute job total.
Old 05-18-2012, 07:10 PM
Cool. Should be here on Wednesday. Lookin forward to it
