Hey cts users look
Hey have any of you guys with a cts have it not show boost? Mine will sAy zero some days others it's fine. I know the truck isn't losing boost and I don't think the map senser is bad. Truck runs fine.any ideas also the first time it did this is when I put in the blue spring.
Sounds to me like an issue with the sensor and not the cts
Yeah I know it does. But why doesn't the truck run rough? When I get home I'll look at it maybe I bumped it or don't have it pluged in all the way after I did my studs
the map sensors can break easily
You know now that I think of it I was hunting around the intake the other day for a socket I dropped wonder if I split the hose
Check for a possible blockage in either the hose or the fitting that screws into the intake manifold. Truthfully the truck should be a dog if the MAP is in fact screwed.
That's what I was thinking. But if the truck runs this good with it broke I don't need to fix it. Cause the truck runs like a bat out of hell.
