Just put 5" exhaust on - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-06-2012, 05:49 AM Thread Starter
casper4203's Avatar
I just put a 5" exhaust by Diamond Eye on my '05. It has a 4" down pipe and no kitty and no muff.
It wasn't too bad doing it. Getting the old system was a little time consuming.
The part I had the hardest time with was clamping the down pipe to the turbo. The flange on the new pipe was a good bit thicker. This would not allow the clamp to squeeze over the joint enough to start the threads on the clamp's bolt.
My neighbor and I took turns... one below and the other yelling at the other to "hold it still!"
I ended up pulling it out and using a worn flap wheel on my angle grinder to take off just a little bit from the flange. It looked as if the machine rolled edge was just not as clean as it should be. The aluminized coating added a little more thickness. It gave me the little bit I needed.
The Diamond Eye used a 2 pc. down pipe and I don't see how it would work otherwise.
I used SS band clamps and would encourage everyone else to do so. This allows you to loosen and adjust / clock the joints to get clearence and angles just right.
This sounds really good. It goes from mellow to aggressive as you "apply the proper amount of force" on the loud peddle.
My wife and daughter giggle and won't quit asking me to drive it.
casper4203 is offline
post #2 of 8 Old 05-06-2012, 07:33 AM
DieselV8's Avatar
Glad to hear it went well, I want to put a 5" on my truck.
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #3 of 8 Old 05-06-2012, 09:34 AM
I just put my TSB 5" diamond eye on 3 weeks ago. I didnt have a problem with the Dp tho. The sound is great and Im glad I went with a 5" instead of the 4". Now I have to order a tip for it. Im going to put a 5" to 7" tip on it in a few weeks.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #4 of 8 Old 05-06-2012, 10:03 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
I have 6" tips on my duals and personally I don't think going bigger than that would look good but to each his own.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #5 of 8 Old 05-06-2012, 04:25 PM Thread Starter
casper4203's Avatar
I put a 5" x 6" x 15" rolled edge on. I'm very happy with it. Anything bigger and my Rotty may try to stick his head in there to find what is making that wissling noise.
post #6 of 8 Old 05-07-2012, 11:13 AM
kingranch250's Avatar
Have same setup 5" diamond eye went with 5 to 6 inch tip and month later decided to go with a stack now its 5 to 8 inch single miter cut
auto merter gauges,03turbo,volant intake,SCTcustom tunes,Harley headlights,recon smoked tail/3rd break,5 inch exhaust 8inch stack,billet grille,jessejames lawsless 20's 33"mud grapplers, jesse james door handles,arp head studs,oynx gaskets,upgraded banjo bolts,river city egr delete kit,air dog 150, 08 tailgate,all lights led,mp8
kingranch250 is offline
post #7 of 8 Old 05-07-2012, 02:31 PM
I havent seen a 7" in person so I was just guessing.. I dont want it to look to big and out of place.. Maybe a nice black rolled end 6"..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #8 of 8 Old 05-08-2012, 09:12 PM
highland512's Avatar
Has anyone went from 4" to 5"? What was the sound difference in the cab? Did you perfer one over the other?
-Matt
'04 350
ZF6
SCT 5015
highland512 is offline
