BPD ext oil cooler install custom mount
Installing the BPD ext oil cooler kit to try to get my EOTs down. Those of you that have read my threads know I run some high EOTs with big trailer, sometimes doubles, in the Vegas heat. Anyway, since I have the 08 front end, i have some free space up front. I talked to BPD tech, and they said it will cool better, but may have some effect on my AC not being as cool. Not a big deal to me cause most the big hills I have to roll the windows down and go full heat just to help not overheating, so even any AC will be better then our normal summer trips to UT! Anyway i build the custom mount today, welded up a sturdy bracket out of 1/4" x 1" mild. Should finish up tomorrow. What ya think?
Geat job JJ. That should do the trick. Do you have a manual fan over ride? If not it would be worth adding one I think. The Air to Oil cooling effective ness is direcctly proportional to the air moving across the heat exchanger.
I agree. You might also ask your custom tune writer to add some parameters so that your clutch engagement occurs based on a lower EOT temp. Right now I don't think ANY tuner modifies the factory setting, which is 230* EOT.
Sweet! Looks great!
Yes that does look GREAT!!
We're almost at that time of year where it gets hot so I'm definitely looking forward to a writeup on the differences noted (if you're doing one of course). I like reading your threads... detailed and informative! While I may not be pulling huge loads yet I've got my list of needed items based on your threads to set my truck up
Sent from my phone. The computer was too far from the couch |
That should work awesome bud!
PS I was able to get Matt @ Gearhead to adjust those parameters for me. I think my fan starts to engage at and EOT of 210* |
I talked to the guys at BP a few years ago when they first came out and asked a few questions. I was still leery as to whether or not their cooler would be able to cool enough. I also told them that I was worried about taking too long for oil to get to operating temps in colder climates(this was before they came out with a thermostat). Anyways we had talked about making a bracket so I could run two of their radiators. I also thought about running a larger single cooler like a 6.0 tranny cooler modified to accept the larger hoses. I never did any of this as I am still running stock cooler and dealing with the temps. I am just thinking out loud and giving some ideas. I hope all works out for you and I would like to know if your temps drop. Another thing I was considering was an electric fan that could be turned on by a thermostat.
got some pretty big dings in them fins
