I think it's stud time - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-04-2012, 04:58 AM Thread Starter
early99strokerr's Avatar
I was towing with my 2005 f-250 probably 8k nothing special, well made the trip headed on my way home when temp started creeping up. When it hit 220 I pulled over checked it out, it was puking
the trip was about 90 miles each way I had to stop 4 times within the 90 miles to fill it back up does that seem right? also when normally driving the truck unloaded she will puke everywhere. just wanted to make sure I'm heading in the right direction before I do studs AGAIN
Early 1999 F-250---SOLD
2004 F-350 SRW---SOLD
2005 F-250-----SOLD
2008 F-350 SRW CC/SB
8" Lift
22x14 American Forces
37" Falken Wild Peaks
DPF/DOC Delete
SCT Livewire
Gear Head Tunes
early99strokerr is offline
post #2 of 5 Old 05-04-2012, 05:07 AM
macoyle's Avatar
Feedback Score: 5 reviews
With your egr deleted I would point towards the hg again. What line are you filling the degas bottle up to tough? If your overfilling it that could be a reason, or your cap is bad. Once they blow your supposed to replace it. Best way is to get a gauge and hook it up and see if your going over 15psi
06 F-250 ccsb King Ranch, 2011 KR interior AC seats, door panels, 3" RC lift, SCT X3, WILDMAN tune, bumpers, Edge CTS, AMSOIL bypass kit, pillar gauges, ARPs, Warren 155s, egr delete, 4" exhaust...the list goes on and on
2004 Toyota 4runner 3" lift Shrockworks bumper and 285's
macoyle is offline
post #3 of 5 Old 05-04-2012, 05:21 AM Thread Starter
This truck still has EGR, and stock bolts.
my 04 was studded and deleted.
I've been filling to the line on the update sticker, and If i put my hand where the cap is supposed to be it builds alot of pressure, I just don't recall my 04 puking this bad when the HG's went.
2005 F-250-----SOLD
8" Lift
DPF/DOC Delete
SCT Livewire
Gear Head Tunes
post #4 of 5 Old 05-04-2012, 05:23 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is a trouble shooting guide.
Troubleshooting coolant loss (white residue around cooling system components(degas))
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 5 Old 05-04-2012, 07:50 AM
Dirty_Stroke's Avatar
I would do an EGR delete before I done studs unless you plan on eventually putting studs in it anyway. The EGR delete is a lot cheaper and it might fix your problem.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
