NEW MAD INFO:::::: - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-02-2012, 12:18 PM Thread Starter
madpowerstroke's Avatar
NEW MAD INFO::::::
I have been doing alot of turbo,work and have gotten alot of Powerstroke turbos and have found out some things to share with the members.I have found out that indeed it is true that a Batmowheel will not be a drop in on a remanufacture turbo.Why? well it seems that the reman is smaller,the compressor housing and compressor wheels are smaller measures 55.5MM/82mm,Stock is 58mm/82mm,so what gives.You buy a reman turbo for your truck and pay 1200-1900.00 and you get a smaller turbo,what a bunch of sh**.So that is why a drop in batmowheel is not a drop in a reman.Now Bullseye the batmowheel maker is not a saint either,this is fact not made up.I bought a gt4088 batmowheel for the Mad stage 2,and guess what it is a powermax compressor wheel.(even marked on box)So you buy a billet wheel for a GT4088 which measures 64.7mm/88mm .72a/r and you end up with a 63.5mm/88mm .58a/r wheel.So they say it'll work it's almost the same???So when the cops pull you over and say why didn't you come to a complete stop at that stop sign and you respond I slowed down it's almost the same,and he tells you to step out of the car and pulls his knight stick out and starts to beating on you.You start yelling stop! stop! and he replies stop or slow down it's almost the same right?Just thought I would share,I work hard and expect to get what I pay for not almost what I pay for.Thanks.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 5 Old 05-02-2012, 12:45 PM
pizza pig's Avatar
Thats not surprising at all. Send them the 4088 wheel and have them make it to those specs
pizza pig is offline
post #3 of 5 Old 05-02-2012, 12:46 PM
so the saying is true, " if you want something done right, you got to do it yourself". go buy a cnc turning center and start cnc machining your own batmowheels, then you will get the tolerances you pay for.
lubbock guy is offline
post #4 of 5 Old 05-02-2012, 12:56 PM
Haha if you need a batmowheel for a 38r let me know I will make ya smoking deal on one! Since you are the mad fabricator you can make it work with something Im sure!
Jason, But you can call me Sir!!!
2001 F-350 CC Dually~Built and tuned by PHP~572/1161ft lbs fuel only~few LEDs here and there
GOPOWERHUNGRY.COM
Lowdown89 is offline
post #5 of 5 Old 05-02-2012, 01:14 PM
Dirty_Stroke's Avatar
That's screwed up man! You'd think as expensive as this aftermarket stuff is that you would get what you pay for. Not some one size fits all crap.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
