Procharger
I have been thinking about doing this for a while now. But i am curious if the stock internals can handle it. If i do it i will run empires procharger but probably do piping and stuff i can fab up myself to save some money. Also was gonna run 285 cc injectors and eventually put a 68 mm turbo behind the procharger. i am open to anyones opinions about this setup.
Yes,I seen that set up before,I can't remember where.I know someone will remember about it.
Do you remember if it ran good and wasent underfueled
Matt from cuttingedge diesel ran the procharger kit on his truck. I've been wanting to do it for a long time. I've been told not to go with the D1SC procharger tho...go with the F1.
whats the difference between the two of them
The F1 is bigger and will push more air.
Danny(imelmo) also ran the procharger kit and he first ran it with the stock vgt turbo.
awesome spooling set up! best part of it.
and like chris said go F1 also dont go 285s please.... 205s are plenty of fuel or 225s if you feel crazy. |
d1-sc with a 70mm precision BB billet turbo 225cc injectors that flowed less than stock at the time
![]() installed on my other truck. I was showing to lope put you can get idea of how it sounds on yet another truck with 225/75s and on 38'' tires. You can see the boost and EGTs on a WOT pull |
I like the procharger setup a lot too.
Matt, why did you decide to get rid of the procharger for the compounds? |
