CFM large mouth intake kit review - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-25-2012, 12:21 PM Thread Starter
I know it's not a big performance gainer and most everyone knows that that but if you didn't now you do. It's not going to give you a noticable difference in horse power per say but I can absolutely tell the difference in the way the truck runs in general. It idles much better and seems to have a little more pull throughout the entire rpm range. Fuel economy I haven't really figured up yet but with the increase in air flow you get from this kit I would say fuel economy may be a tad better as well. It's super easy to install and I love how on my 04 it eleminates the useless throttle plate. Not to mention it comes with a huge boost tube much larger than the stock tube. While other kits may be cheaper I think this one is the best complete kit other than maybe the banks kit but it was well worth it's price tag in my opinion. Others may disagree but my truck runs a lot smoother throughout now so that's a win in my book.
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #2 of 6 Old 04-25-2012, 02:21 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Thanks for the review!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 6 Old 04-25-2012, 02:26 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
I think it's all in your head and if you put it on the dyno it would prove that. There is no increased air flow into the cylinders because the intake manifold and the heads are the restriction point.
If you have a 1/4 nozzle on a hose it doesn't much matter whether the hose is 3/4" or 1", It's still only going to flow what will go through the 1/4" nozzel.
I have a carbon fiber Largemouth on my truck. It may change the intake sound but it really isn't flowing more air. Congrats on the purchase anyway. They look cool and give you a place to pull boost for a mechanical gauge or hook up some Meth/water injection or NOS.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #4 of 6 Old 04-25-2012, 02:48 PM
ebusa's Avatar
I noticed a smoother idle as well when I had mine. Also noticed more noise. I ended up removing it since it leaked oil all the time due to the flat style gasket.
I tapped the stock elbow and put that back on since it has an "O-ring" gasket seal. No more leaks.
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #5 of 6 Old 04-25-2012, 03:26 PM
strokin6L's Avatar
Quoted: 3 Post(s)
I have the carbon fiber large mouth kit. Only reason i got it is because it already had the drilled and tapped ports for my water injection nozzles and boost reference.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #6 of 6 Old 11-08-2012, 06:24 PM
livinlots26's Avatar
Then why in my shop do I have 1/2 inch and 1 inch air lines going into 2 identical Ingersoll guns... one will break a half inch bolt the other won't. It's all about volume and I would think less restriction any where in the intake line would be better.
livinlots26 is offline
