Another Quick EGR Delete Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-24-2012, 09:00 PM Thread Starter
I bought a used 2006 F350 6.0L super duty. I have no way to attain past mods or maintenance done. Is it possible to tell by guage whether an EGR delete has been installed?
Thanks for your patience.
Mike
mward3 is offline
post #2 of 3 Old 04-24-2012, 09:25 PM
turbotibbo's Avatar
are you talking about the 6.0 if so just look and see if the egr coolrer is still there .should be to the left of the turbo long metal rectangle 12inch or so.
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 3 Old 04-24-2012, 09:40 PM
Term3's Avatar
If its a sneaky delete the only way is to pull the EGR valve and if it does not have soot on it then the cooler has been welded closed.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
