Gyrphon orderd - Ford Powerstroke Diesel Forum
post #1 of 33 Old 04-24-2012, 04:42 PM Thread Starter
elm302's Avatar
Feedback Score: 3 reviews
Gyrphon orderd
I ordered the gryphon ficm tuner from php last Wednesday. Got notified should have it Thursday. Can't wait to try this baby out. I plan on running the Hercules tune first. I like to play with fire Haha. Does anyone know if a egt probe off a edge juice will work with the monitor ?
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #2 of 33 Old 04-24-2012, 05:28 PM
Powerstroke Techie
Lilpooh's Avatar
Man.... You gotta wait till Thursday!! LOL! I've been driving around with Atlas 40 the past couple of days, I like Atlas 80 and Hercules better. Gonna have to load up Hercules tomorrow.
I'm not sure if the probe is interchangeable, you would have to ask Bill at PHP.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 33 Old 04-24-2012, 05:30 PM Thread Starter
elm302's Avatar
Ya ya rub it in lol. How long does it take to swap tunes ?
elm302 is offline
post #4 of 33 Old 04-24-2012, 06:31 PM
Powerstroke Techie
Lilpooh's Avatar
About 5 minutes. You will remove the FICM relay from under the hood, connect the Gryphon to the OBDII, follow the instructions on the screen, turn key on then off, then on again, scroll to "programs", scroll to which ever year and tune you have/want, hit enter, the tune loads in about 30 seconds, after it loads then you turn key off, and re-install FICM relay.
I typed that from memory, so I might be off a little. LOL!!
I'm gonna rub it in a little more! HA!!
Lilpooh is offline
post #5 of 33 Old 04-24-2012, 06:38 PM
This little contraption is catching my eye. Either of you guys mind me asking how much they run?
2016 F250 Lariat
the06wildebeast is offline
post #6 of 33 Old 04-24-2012, 06:52 PM
hazard's Avatar
is this something you keep or send back when done programming? what is the advantages and what is the price?
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #7 of 33 Old 04-24-2012, 06:57 PM
I talked to PHP and you can get the programer with all the programs and tune your truck and send it back that costs $250 and when you send it back you get a $150 return! Or you can by the whole set up and keep it for $400. Iam going to get this thing but first when i get back from TS on May 20th im going to stud my truck and but some 175's in it!
2008 ccsb F250 lariat
SCT tuned by Gearhead Single 371, MPD CCV RCD pushrods ARPS
SOLD!
2003 f250 4x4 crewcab lariat (03 Turbo)
Perfomance:
ARPs, 175/75 Industrial Injection, EGR delete, 5" MBRP,6.4 Banjo Bolts, Coolant filter SCT Innovative Xtreme X, PHP FICM tuner, AirDogII with Sump
2.5" level, 18" monsters with 33/13.00/18 Nitto Terra Grapplers
powerstroke 825 is offline
post #8 of 33 Old 04-24-2012, 06:59 PM
Powerstroke Techie
Lilpooh's Avatar
The Gryphon FICM tuner is $399, this programmer you get to keep as your own. The advantage is, you can swap FICM tunes as much as you want to suit your needs. For example, when towing you will use either the Econ or Atlas 40 with a ECM tune like Vivian's tow/agg tune. Or if you want to run balls out, load up either the Atlas 80 or Hercules FICM tune with a ECM race tune like the SRL, Looney, x-race, ect,ect.
The combinations are at you disposal, I have 26 custom SCT tunes and now have 4 FICM tunes.
Lilpooh is offline
post #9 of 33 Old 04-25-2012, 02:20 AM Thread Starter
elm302's Avatar
That's why I went with this setup. I didn't want to be limited to one tune. Cause I'm the kinda person that usually drives with a full race file all the time. So now I'm probly gonna be hijacking every ups truck I see Haha
elm302 is offline
post #10 of 33 Old 04-25-2012, 07:29 AM
So what made you guys pick PHP over Innovative?
2016 F250 Lariat
