Fuel System - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-20-2012, 03:04 PM Thread Starter
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Fuel System
Okay, so my stock fuel pump is getting a little weak. Fuel pressure will drop 2-3 PSI under normal acceleration, and drops quickly under WOT once I hit overdrive (I have to let off at 65 MPH cause it will hit 40 and still dropping.
Here's my issue. I'm broke. April 15th RAPED me this year. I don't plan on upgrading injectors anytime soon. What would be my best option on a budget? AD 150 behind the stock HFCM? Raptor pump?
Any ideas and comments are greatly appreciated.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #2 of 13 Old 04-20-2012, 03:26 PM
pizza pig's Avatar
your stock pump is weak, replace the pump dont waste the money to band aid the problem. Is your fuel pressure spring updated? I would just get a stock replacement HFCM and rebuild the regulator.
pizza pig is offline
post #3 of 13 Old 04-20-2012, 03:40 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Just get another stocker and stick in there.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 13 Old 04-20-2012, 04:09 PM
elm302's Avatar
Feedback Score: 3 reviews
Same thing I went threw today at idle I was at 30 psi and would drop to 0 over half throttle. Replaced oem pump got it from oriellys for 220. Got my pressure back up to 40psi. Went too ford got the blue spring 72.00 and now I'm idling at 70psi and it never drops below 65 psi.
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #5 of 13 Old 04-20-2012, 04:26 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Yea the ford regulator sucks monkey nuts. I know RR kits arent required but regardless, I like the fact that they delete and open up the factory regulator and put higher flowing banjo bolts in the loop. Of course you can get RR kits from Dozer's Diesel that get rid of the banjo bolts all together and replace with 90* fittings.
Nate
post #6 of 13 Old 04-20-2012, 04:26 PM Thread Starter
Alright guys, you've convinced me. Just gonna throw another stocker in there. Who's got the best prices?
I already have the updated FPR.
Blake
post #7 of 13 Old 04-20-2012, 04:30 PM
Term3's Avatar
Quoted: 2 Post(s)
I'm assuming you have changed the fuel filters.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 13 Old 04-20-2012, 04:54 PM Thread Starter
Yup, Motorcraft filters with 3,000 miles.
Blake
post #9 of 13 Old 04-20-2012, 05:12 PM
elm302's Avatar
Got mine from oriellys
elm302 is offline
post #10 of 13 Old 04-20-2012, 07:59 PM
Wed Turner's Avatar
Sent you a PM. I might have a cheaper option for you.
2003 Excursion Limited 6.0 2wd
Transmission built by
/ ECM tunning by
/ FICM tunning by
Coldside Intercooler Kit /
EGR Delete /
Coolant Filter / GoGo Diesel direct clutch solenoid / AFE Stage II Intake / Ford Blue Spring / 6.4 Banjo Bolts / Zoodad / 1.5" front sway bar by
/ Ford 30mm rear sway bar
Wed Turner is offline
