6.0 Straight Pipe - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 42 Old 04-16-2012, 07:52 AM Thread Starter
6.0 Straight Pipe
In the market to straight pipe my 2005 6.0 to basically make it sound louder, not really worried about the performance upgrade...
I have done a lot of research but have some questions.
I have heard to stick with the 3.5" because it is the best fit. The link below is the one I am currently looking at
Ford 6L Powerstroke Diesel Stock Muffler Delete Pipe
What is the difference between this $64.99 and the ones that are $250+?
MBRP S6212PLM 4" Straight pipe turbo back exhaust for 03-07 Ford 6.0L Powerstrok
Wanting to delete the muffler but should I also delete the Cat while im at it too?
Thanks in advance
souther32 is offline
post #2 of 42 Old 04-16-2012, 08:01 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
Stock system:
3" downpipe turns into a 3.5" under the truck... just getting that delete pipe will keep the same 3.5" diameter exhuast...
The other system you are looking at is going to give you a 3.5" downpipe with a 4" under the truck... Thus making it Bigger/ louder/ less restrictive!
I would also suggest that you NOT worry about buying a system with a 4" downpipe
Many guys around my area has the Diamond Eye Exhuast which has the 4" downpie (including myself) and the installation is not as hard as some make it to be
Also, the Diamond Eye kits are USUALLY the least expensive and the quality is great. A steel pipe is a steel pipe.. can't really get a "more" better one
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 42 Old 04-16-2012, 10:09 PM Thread Starter
Difference?
Diamond Eye K4338A 4" Aluminized Cat Back Fits 03-07 Ford 6.0L
I realize that one doesn't have a muffler... Is it worth the extra penny to cut out the muffler?
post #4 of 42 Old 04-16-2012, 11:02 PM
back to business
07OUTLAW's Avatar
Here's the deal with exhaust -
-Stainless is slightly better (last longer) than aluminized.
-aftermarket (3.5 or 4 inch) down pipe is less restrictive than stock, do it.
- 5 inch sounds a little "deeper" but dosent give you any benifit over 4 inch.
-Get rid of the cat, it's a huge restriction
-aftermarket mufflers are all a "flow through" design (they are wide open if you look through them) less restrictive than the stock muffler. They quiet the exhaust, but it'll be louder than stock.
-straight pipe (no cat no muffler) is the loudest, not really that loud though
- tips will change the sound of the exhaust a little (think, yelling vs yelling through a cone) but are mostly for looks
- decide if you want aluminized or stainless / cat or no cat / muffler or no muffler / tip or no tip.... then get the cheapest one you can find. That's the best one you can get
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #5 of 42 Old 04-17-2012, 07:16 AM Thread Starter
Thanks for the info above, you're the man
From a installation aspect, installing the 4' pipe Turbo Back, is it an easy fit or would it be easier installing the Cat Back?
post #6 of 42 Old 04-17-2012, 07:20 AM
Quoted: 370 Post(s)
It is not EASY...but the worst part is getting the old down pipe out, (many guys chop it up with a sawzall)
BUT, It is Worth it for cooling EGT's, freeing up the restriction in the stock exhuast and will sound alot better
Studded and Deleted
The Following User Says Thank You to Six0~Stroker For This Useful Post:
Redvtwin2 (12-22-2016)
post #7 of 42 Old 04-17-2012, 07:34 AM Thread Starter
MBRP S6212PLM 4" Straight pipe turbo back exhaust for 03-07 Ford 6.0L Powerstroke - No Muffler - Aluminized
So everything in this kit SHOULD allow me to install this myself? Just making sure before I buy this product.
Thanks
post #8 of 42 Old 04-17-2012, 07:37 AM
Quoted: 370 Post(s)
Yep
That is the kit!
Studded and Deleted
post #9 of 42 Old 04-17-2012, 07:39 AM Thread Starter
Scratch that, im taking your advise and going with Diamond Eye
Diamond Eye K4346A-RP 4" Turbo-Back Off-Road No Muffler Single AL: 2003-2007 Ford 6.0L Powerstroke F250/f350 4X4 Automatic Only
Thanks again for all yalls help
post #10 of 42 Old 04-17-2012, 07:44 AM
Quoted: 370 Post(s)
Good call
Try this though, call up that company and see if they will throw in a 5" tip
I don't think this kit comes with one and they might either throw one in or give you a deal on it
and don't tell them your set on their kit... tell them your interested but dont like the fact that it doesn't come with a tip like other Kits
Studded and Deleted
